[GRASSweb-list]markus: web contact.inc,1.2,1.3
grass at intevation.de grass at intevation.de
Mon Jan 23 06:16:48 EST 2006
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv26602
Modified Files:
	contact.inc
Log Message:
privacy issues
Index: contact.inc
RCS file: /grassrepository/web/contact.inc,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- contact.inc	10 Nov 2005 20:03:14 -0000	1.2
+++ contact.inc	23 Jan 2006 11:16:46 -0000	1.3
@@ -13,9 +13,11 @@
 right people:
 <ul>
-<li> Web site link broken? Write to <a href="mailto:weblist at grass.itc.it">weblist</a>.
+<li> Web site link broken? Write to <a href="mailto:weblist at grass.itc.it">weblist</a>.
+     Note, that this is a Web based mailing list.
 <li> Odd grammar found? Suggestions for web site updates? Send improved text pieces to
-      <a href="mailto:weblist at grass.itc.it">weblist</a>.
+      <a href="mailto:weblist at grass.itc.it">weblist</a>. Note, that this is a
+      Web based mailing list.
 <li> No idea how to use GRASS? Contact the user's mailing list within the
       <a href="community/index.php">community</a>.
 <li> You know how to make things better? Perfect! Read
@@ -24,6 +26,18 @@
 The main GRASS server is hosted at ITC-irst, Trento, Italy
 (<a href="http://mpa.itc.it">MPBA group</a>).
+<P>
+<h3>Don't want your message found by search engines?</h3>
+To avoid that you message appears in search engines, you can add a special
+email header to your message. See
+<a href="http://en.wikipedia.org/wiki/X-No-Archive">wikipedia.org - X-No-Archive</a>
+for details.
+<P>
+If you want to contact us and not write to above indicated 'weblist', please
+contact a GRASS developer directly.
 <div align="right">
 <i>Last change: $Date$ </i><br>
More information about the grass-web mailing list
