[GRASSweb-list]
scott: web/devel i18n.inc, 1.16, 1.17 i18n_stats.inc, 1.16, 1.17
grass at intevation.de
Thu Jul 27 20:16:06 EDT 2006
Author: scott
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv27007
Modified Files:
i18n.inc i18n_stats.inc
Log Message:
language and formatting cleanup
Index: i18n.inc
RCS file: /grassrepository/web/devel/i18n.inc,v
retrieving revision 1.16
retrieving revision 1.17
diff -u -d -r1.16 -r1.17
--- i18n.inc 12 Jun 2006 19:21:59 -0000 1.16
+++ i18n.inc 28 Jul 2006 00:16:04 -0000 1.17
@@ -7,13 +7,13 @@
<a name="translations"></a>
<h3>The idea</h3>
-The great interest in GRASS suggests to translate GRASS messages to
-other languages than english. The "infrastructure" to
+The great worldwide interest in GRASS suggests value in translating GRASS messages to
+languages other than english. The "infrastructure" to
support single-byte as well as multi-byte character sets was implemented
(based on <a href="http://www.foss4g.org/">the FOSS4G efforts</a>).
<P>
-The GRASS Development Team is seeking for translators.
+The GRASS Development Team is seeking translators.
Please subscribe to the dedicated mailing list at
<p>
@@ -65,7 +65,7 @@
Translation <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/README?rev=HEAD&content-type=text/vnd.viewcvs-markup">README</a>
<P>
-Do change to a certain LOCALE (if the system doesn't do it for you or
+To change to a certain LOCALE (if the system doesn't do it for you or
for exploring other languages), do the following steps:
<small>
Index: i18n_stats.inc
RCS file: /grassrepository/web/devel/i18n_stats.inc,v
--- i18n_stats.inc 29 May 2006 12:44:06 -0000 1.16
+++ i18n_stats.inc 28 Jul 2006 00:16:04 -0000 1.17
@@ -5,10 +5,11 @@
// function zur Erstellung der tabellen
+// function to create the tables
function generate_table($file) {
$last_modified = filemtime($file);
- // einlesen der Datei
+ // einlesen der Datei - read in data
$array = file($file);
// read in the iso-table
@@ -20,7 +21,7 @@
$array_iso1 = array();
foreach($array_iso as $id => $value) {
$array_iso1 = explode("\"", $value);
- // neue arrays schreiben
+ // neue arrays schreiben - write new arrays
array_push($array_iso2, $array_iso1[7]);
array_push($array_iso3, $array_iso1[1]);
@@ -42,8 +43,10 @@
$arr5 = array();
foreach($array as $lines => $value) {
// array an Leerzeichen unterteilen
+ // space delimited array
$split = explode(" ", $value);
// neues Array jeweils für die einzelnen Spalten schreiben
+ // write new array for each column
array_push($arr2, $split[0]);
array_push($arr3, $split[1]);
array_push($arr4, $split[4]);
@@ -51,8 +54,10 @@
// Sortieren der Spalte 2
+ // sort by split 2 ?
arsort($arr3, SORT_ASC);
// ausgabe in tabelle basteln
+ // output table (?)
foreach($arr3 as $names => $values) {
$split2 = explode("_", $arr2[$names]);
$split3 = explode(".", $split2[1]);
@@ -88,15 +93,16 @@
<hr>
<a name="statistics"></a>
-<h2>Statistics of current GRASS internationalization (i18N) status</h1>
+<h2>Statistics of current GRASS internationalization (i18N) status</h2>
The table is ordered by number of translated messages per language.
-The two characters code indicating the language is based on Alpha-2 code of
+The two character codes indicate the language, based on the Alpha-2 code of
<a href="http://www.loc.gov/standards/iso639-2/englangn.html">ISO 639-1</a>.
For download of a currently sleeping translation, please either get the
file directly from the GRASS-CVS or see above.
<?php
// ausgabe in HTML-Tabelle durch Funktion generate_table()
+// output in HTML table through function generate_table()
echo "<h2>GRASSLIBS</h2>\n";
generate_table($file_libs);
More information about the grass-web
