[GRASSweb-list]markus: web/grass61/binary/linux README.html,1.1,1.2
grass at intevation.de
Tue Mar 28 02:43:25 EST 2006
Author: markus
Update of /grassrepository/web/grass61/binary/linux
In directory doto:/tmp/cvs-serv14934
Modified Files:
README.html
Log Message:
slightly less mess
Index: README.html
RCS file: /grassrepository/web/grass61/binary/linux/README.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- README.html 14 Apr 2005 08:58:00 -0000 1.1
+++ README.html 28 Mar 2006 07:43:23 -0000 1.2
@@ -43,25 +43,22 @@
<h3>Libraries</h3>
The following libraries are required:
<ul>
- <li>libpq (e.g. libpq3-7.3.4-2mdk.i586.rpm)</li>
- <li>proj (e.g. proj-4.4.7-1mdk.i586.rpm)</li>
- <li>libproj (e.g. libproj0-4.4.7-1mdk.i586.rpm) </li>
- <li>libgdal(e.g. libgdal0-1.1.9-2mdk.i586.rpm) </li>
+ <li>libpq (e.g. libpq3 or libpq4)</li>
+ <li>proj (e.g. proj)</li>
+ <li>libproj (e.g. libproj) </li>
+ <li>libgdal(e.g. libgdal) </li>
</ul>
and, recommended, also:
<ul>
- <li>tcl (e.g. tcl-8.3.3-21mdk.i586.rpm)</li>
- <li>tk (e.g. tk-8.3.3-21mdk.i586.rpm)</li>
- <li>gdal tools (e.g. gdal-1.1.9-2mdk.i586.rpm)</li>
- <li>libfftw (must be fft2, e.g. libfftw2-2.1.5-2mdk.i586.rpm)</li>
- <li>libgrass (e.g. libgrass5-1.0.0-1mdk.src.rpm - but only if inserted in one of above packages as dependency)<br>
- </li>
+ <li>tcl (e.g. tcl)</li>
+ <li>tk (e.g. tk)</li>
+ <li>gdal tools (e.g. gdal)</li>
+ <li>libfftw (fftw2 or fftw3)</li>
</ul>
optional:<br>
<ul>
- <li>libgdal0-devel-1.1.9-2mdk.i586.rpm</li>
- <li>libgrass5_0-devel-1.0.0-1mdk.i586.rpm</li>
- <li>libproj0-devel-4.4.7-1mdk.i586.rpm</li>
+ <li>libgdal0-devel</li>
+ <li>libproj0-devel</li>
</ul>
You can find these RPMs at <a href="http://www.rpmfind.net/">www.rpmfind.net</a>
or <a href="http://rpm.pbone.net">rpm.pbone.net</a>
More information about the grass-web
