[GRASSweb-list]markus: web/nviz index.html,1.8,1.9
grass at intevation.de grass at intevation.de
Wed Mar 29 14:36:23 EST 2006
Author: markus
Update of /grassrepository/web/nviz
In directory doto:/tmp/cvs-serv11989
Modified Files:
Log Message:
simplified
Index: index.html
RCS file: /grassrepository/web/nviz/index.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- index.html	11 Jan 2005 08:56:26 -0000	1.8
+++ index.html	29 Mar 2006 19:36:21 -0000	1.9
@@ -27,7 +27,7 @@
 <ul>
 <li>
-<a href="../gdp/nviz/index.html">NVIZ Tutorial</a></li>
+<a href="../grass61/manuals/html61_user/nviz.html">NVIZ Tutorial</a></li>
 <li>
 <a href="../community/nvizlist.html">NVIZ
@@ -46,16 +46,7 @@
 <li>
 You can generate MPEG animations
-with <a href="../nviz/index.html">NVIZ</a>.
-You need the <a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/encode/">mpeg_encoder</a>
-installed (often already present as 'ppmtompeg' from NetPBM, just symlink).</li>
-<br>Here is a file to control
-the mpeg_encode software: <a href="../faq/mpegparam.txt">mpegparam.txt</a>.
-Adjust the file name and the number of images you want to convert. Finally
-use <a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/">mpeg_play</a>
-to play the film.
+with <a href="../grass61/manuals/html61_user/nviz.html">NVIZ</a> (needs GRASS compiled with ffmpeg support).
 </ul>
 <hr>
@@ -81,7 +72,7 @@
 <!-- FOOTER -->
 <hr>
-<DIV ALIGN=right>&copy; 1999-2005 GRASS Development Team<br>
+<DIV ALIGN=right>&copy; 1999-2006 GRASS Development Team<br>
  <a href="mailto:weblist at grass.itc.it">Comments</a> about this page |
  <a href="../faq/index.html">FAQ</a> |
  <a href="../download/index.php">Download</a> |
More information about the grass-web mailing list
