[GRASSweb-list] markus: web/grass57/tutorial index.html, 1.32,
1.33 intro.html, 1.9, 1.10 links.html, 1.18, 1.19
grass at intevation.de
Wed May 24 08:18:09 EDT 2006
Author: markus
Update of /grassrepository/web/grass57/tutorial
In directory doto:/tmp/cvs-serv22048/grass57/tutorial
Modified Files:
index.html intro.html links.html
Log Message:
Wiki refs updated
Index: index.html
RCS file: /grassrepository/web/grass57/tutorial/index.html,v
retrieving revision 1.32
retrieving revision 1.33
diff -u -d -r1.32 -r1.33
--- index.html 15 Mar 2005 09:38:57 -0000 1.32
+++ index.html 24 May 2006 12:18:07 -0000 1.33
@@ -25,7 +25,7 @@
<b>NOTE:</b> This tutorial is refering to GRASS 5.7. Meanwhile (2005), GRASS 6.0.0
has been published. An updated (but unfortunately still incomplete) version
of this tutorial is available here:
-<a href="http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorial">GRASS Six Tutorial</a>.
+<a href="http://grass.gdf-hannover.de/wiki/GRASS_6_Tutorial">GRASS Six Tutorial</a>.
<p>
<p>
The Free Software/Open Source GIS GRASS 5.7 is under development since 2002.
@@ -36,7 +36,7 @@
management.
<P>
-See also the <a href="http://grass.gdf-hannover.de/twiki/bin/view/GRASS/ModulePortingList"> Old GRASS modules porting status to 6.0</a>.
+See also the <a href="http://grass.gdf-hannover.de/wiki/GRASS_Module_Porting_List"> Old GRASS modules porting status to 6.0</a>.
<P>
<table>
Index: intro.html
RCS file: /grassrepository/web/grass57/tutorial/intro.html,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- intro.html 28 Mar 2006 08:25:01 -0000 1.9
+++ intro.html 24 May 2006 12:18:07 -0000 1.10
@@ -27,7 +27,7 @@
<h3>The default settings</h3>
Index: links.html
RCS file: /grassrepository/web/grass57/tutorial/links.html,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- links.html 8 Feb 2005 21:51:25 -0000 1.18
+++ links.html 24 May 2006 12:18:07 -0000 1.19
@@ -57,16 +57,16 @@
<li>PostGIS: <a href=http://postgis.refractions.net/>PostGIS</a>
<li>Geometry Converters:
<ul>
-<li>Converter: <a href=http://postgis.refractions.net/download.php>PostGIS with shp2pgsql</a>:<br>
+<li>Converter: <a href=http://postgis.refractions.net/download/>PostGIS with shp2pgsql</a>:<br>
<tt>shp2pgsql -D lakespy2 lakespy2 test > lakespy2.sql</tt>
<li>Converter: <a href=http://avce00.maptools.org/>avc E00 tools</a>
<li>Converter: <a href=http://e00pg.sourceforge.net/>e00pg</a> (E00 to PostGIS
filter)
-<li>Converter: <a href=http://www.remotesensing.org/gdal/ogr/>ogrinfo and
+<li>Converter: <a href=http://www.gdal.org/ogr/>ogrinfo and
ogr2ogr</a> (GIS vector format converter and
library, e.g. ArcInfo or SHAPE -> PostGIS)<br>
<tt>ogr2ogr -f "PostgreSQL" shapefile ??</tt>
-<li><a href=http://www.remotesensing.org/gdal/ogr/drv_pg.html>ogr2ogr - PostgreSQL driver docs</a>
+<li><a href=http://www.gdal.org/ogr/drv_pg.html>ogr2ogr - PostgreSQL driver docs</a>
<li><a href=http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerWiki>MapServerWiki</a>
</ul>
<li>Vector clipping/intersection software and theory:
More information about the grass-web
