[GRASSweb-list] markus: web/feed pear.php, NONE, 1.1 rss.php, NONE,
1.1 parser.php, NONE, 1.1 rss-icon.gif, NONE, 1.1
grass at intevation.de
Tue Oct 31 05:31:03 EST 2006
Author: markus
Update of /grassrepository/web/feed
In directory doto:/tmp/cvs-serv27616
Added Files:
Log Message:
added new RSS feed thing (thanks to Peter Misovic)
--- NEW FILE: pear.php ---
<?php
// | PEAR, the PHP Extension and Application Repository |
// | Copyright (c) 1997-2004 The PHP Group |
// | This source file is subject to version 3.0 of the PHP license, |
// | that is bundled with this package in the file LICENSE, and is |
// | available through the world-wide-web at the following url: |
// | http://www.php.net/license/3_0.txt. |
// | If you did not receive a copy of the PHP license and are unable to |
// | obtain it through the world-wide-web, please send a note to |
// | license at php.net so we can mail you a copy immediately. |
// | Authors: Sterling Hughes <sterling at php.net> |
// | Stig Bakken <ssb at php.net> |
// | Tomas V.V.Cox <cox at idecnet.com> |
[...1017 lines suppressed...]
return sprintf('[%s: message="%s" code=%d mode=%s level=%s '.
'prefix="%s" info="%s"]',
strtolower(get_class($this)), $this->message, $this->code,
implode("|", $modes), $levels[$this->level],
$this->error_message_prefix,
$this->userinfo);
* Local Variables:
* mode: php
* tab-width: 4
* c-basic-offset: 4
* End:
--- NEW FILE: rss.php ---
<?php
// vim: set expandtab tabstop=4 shiftwidth=4 fdm=marker:
// | PHP Version 4 |
// | Copyright (c) 1997-2003 The PHP Group |
// | This source file is subject to version 2.02 of the PHP license, |
// | available at through the world-wide-web at |
// | http://www.php.net/license/2_02.txt. |
// | Authors: Martin Jansen <mj at php.net> |
// $Id: rss.php,v 1.1 2006/10/31 10:31:01 markus Exp $
require_once 'parser.php';
* RSS parser class.
* This class is a parser for Resource Description Framework (RDF) Site
* Summary (RSS) documents. For more information on RSS see the
* website of the RSS working group (http://www.purl.org/rss/).
* @author Martin Jansen <mj at php.net>
* @version $Revision: 1.1 $
* @access public
class XML_RSS extends XML_Parser
// {{{ properties
* @var string
var $insideTag = '';
* @var string
var $activeTag = '';
* @var array
var $channel = array();
* @var array
var $items = array();
* @var array
var $item = array();
* @var array
var $image = array();
* @var array
var $textinput = array();
* @var array
var $textinputs = array();
* @var array
var $parentTags = array('CHANNEL', 'ITEM', 'IMAGE', 'TEXTINPUT');
* @var array
var $channelTags = array('TITLE', 'LINK', 'DESCRIPTION', 'IMAGE',
'ITEMS', 'TEXTINPUT');
* @var array
var $itemTags = array('TITLE', 'LINK', 'DESCRIPTION', 'PUBDATE');
* @var array
var $imageTags = array('TITLE', 'URL', 'LINK');
var $textinputTags = array('TITLE', 'DESCRIPTION', 'NAME', 'LINK');
* List of allowed module tags
* Currently Dublin Core Metadata and the blogChannel RSS module
* are supported.
* @var array
var $moduleTags = array('DC:TITLE', 'DC:CREATOR', 'DC:SUBJECT', 'DC:DESCRIPTION',
'DC:PUBLISHER', 'DC:CONTRIBUTOR', 'DC:DATE', 'DC:TYPE',
'DC:FORMAT', 'DC:IDENTIFIER', 'DC:SOURCE', 'DC:LANGUAGE',
'DC:RELATION', 'DC:COVERAGE', 'DC:RIGHTS',
'BLOGCHANNEL:BLOGROLL', 'BLOGCHANNEL:MYSUBSCRIPTIONS',
'BLOGCHANNEL:MYSUBSCRIPTIONS', 'BLOGCHANNEL:CHANGES');
// {{{ Constructor
* Constructor
* @access public
* @param mixed File pointer or name of the RDF file.
* @return void
function XML_RSS($handle = '')
$this->XML_Parser();
if (@is_resource($handle)) {
$this->setInput($handle);
} elseif ($handle != '') {
$this->setInputFile($handle);
} else {
$this->raiseError('No filename passed.');
// {{{ startHandler()
* Start element handler for XML parser
* @access private
* @param object XML parser object
* @param string XML element
* @param array Attributes of XML tag
* @return void
function startHandler($parser, $element, $attribs)
switch ($element) {
case 'CHANNEL':
case 'ITEM':
case 'IMAGE':
case 'TEXTINPUT':
$this->insideTag = $element;
break;
default:
$this->activeTag = $element;
// {{{ endHandler()
* End element handler for XML parser
* If the end of <item>, <channel>, <image> or <textinput>
* is reached, this function updates the structure array
* $this->struct[] and adds the field "type" to this array,
* that defines the type of the current field.
* @access private
* @param string
* @return void
function endHandler($parser, $element)
if ($element == $this->insideTag) {
$this->insideTag = '';
$this->struct[] = array_merge(array('type' => strtolower($element)),
$this->last);
if ($element == 'ITEM') {
$this->items[] = $this->item;
$this->item = '';
if ($element == 'IMAGE') {
$this->images[] = $this->image;
$this->image = '';
if ($element == 'TEXTINPUT') {
$this->textinputs = $this->textinput;
$this->textinput = '';
$this->activeTag = '';
// {{{ cdataHandler()
* Handler for character data
* @access private
* @param string CDATA
* @return void
function cdataHandler($parser, $cdata)
if (in_array($this->insideTag, $this->parentTags)) {
$tagName = strtolower($this->insideTag);
$var = $this->{$tagName . 'Tags'};
if (in_array($this->activeTag, $var) ||
in_array($this->activeTag, $this->moduleTags)) {
$this->_add($tagName, strtolower($this->activeTag),
$cdata);
// {{{ defaultHandler()
* Default handler for XML parser
* @access private
* @return void
function defaultHandler($parser, $cdata)
return;
// {{{ _add()
* Add element to internal result sets
* @access private
* @param string Name of the result set
* @param string Fieldname
* @param string Value
* @return void
* @see cdataHandler
function _add($type, $field, $value)
if (empty($this->{$type}) || empty($this->{$type}[$field])) {
$this->{$type}[$field] = $value;
} else {
$this->{$type}[$field] .= $value;
$this->last = $this->{$type};
// {{{ getStructure()
* Get complete structure of RSS file
* @access public
* @return array
function getStructure()
return (array)$this->struct;
// {{{ getchannelInfo()
* Get general information about current channel
* This function returns an array containing the information
* that has been extracted from the <channel>-tag while parsing
* the RSS file.
* @access public
* @return array
function getChannelInfo()
return (array)$this->channel;
// {{{ getItems()
* Get items from RSS file
* This function returns an array containing the set of items
* that are provided by the RSS file.
* @access public
* @return array
function getItems()
return (array)$this->items;
// {{{ getImages()
* Get images from RSS file
* This function returns an array containing the set of images
* @access public
* @return array
function getImages()
return (array)$this->images;
// {{{ getTextinputs()
* Get text input fields from RSS file
* @access public
* @return array
function getTextinputs()
return (array)$this->textinputs;
--- NEW FILE: parser.php ---
<?php
// | Author: Stig Bakken <ssb at fast.no> |
// | Stephan Schmidt <schst at php-tools.net> |
// $Id: parser.php,v 1.1 2006/10/31 10:31:01 markus Exp $
* XML Parser class.
* This is an XML parser based on PHP's "xml" extension,
* based on the bundled expat library.
* @category XML
* @package XML_Parser
* @author Stig Bakken <ssb at fast.no>
* @author Tomas V.V.Cox <cox at idecnet.com>
* @author Stephan Schmidt <schst at php-tools.net>
* uses PEAR's error handling
require_once 'pear.php';
* resource could not be created
define('XML_PARSER_ERROR_NO_RESOURCE', 200);
* unsupported mode
define('XML_PARSER_ERROR_UNSUPPORTED_MODE', 201);
* invalid encoding was given
define('XML_PARSER_ERROR_INVALID_ENCODING', 202);
* specified file could not be read
define('XML_PARSER_ERROR_FILE_NOT_READABLE', 203);
* invalid input
define('XML_PARSER_ERROR_INVALID_INPUT', 204);
* remote file cannot be retrieved in safe mode
define('XML_PARSER_ERROR_REMOTE', 205);
* XML Parser class.
* Notes:
* - It requires PHP 4.0.4pl1 or greater
* - From revision 1.17, the function names used by the 'func' mode
* are in the format "xmltag_$elem", for example: use "xmltag_name"
* to handle the <name></name> tags of your xml file.
* @category XML
* @todo create XML_Parser_Namespace to parse documents with namespaces
* @todo create XML_Parser_Pull
* @todo Tests that need to be made:
* - mixing character encodings
* - a test using all expat handlers
* - options (folding, output charset)
* - different parsing modes
class XML_Parser extends PEAR
// {{{ properties
* XML parser handle
* @var resource
* @see xml_parser_create()
var $parser;
* File handle if parsing from a file
* @var resource
var $fp;
* Whether to do case folding
* If set to true, all tag and attribute names will
* be converted to UPPER CASE.
* @var boolean
var $folding = true;
* Mode of operation, one of "event" or "func"
* @var string
var $mode;
* Mapping from expat handler function to class method.
* @var array
var $handler = array(
'character_data_handler' => 'cdataHandler',
'default_handler' => 'defaultHandler',
'processing_instruction_handler' => 'piHandler',
'unparsed_entity_decl_handler' => 'unparsedHandler',
'notation_decl_handler' => 'notationHandler',
'external_entity_ref_handler' => 'entityrefHandler'
* source encoding
* @var string
var $srcenc;
* target encoding
* @var string
var $tgtenc;
* handler object
* @var object
var $_handlerObj;
// {{{ constructor
* Creates an XML parser.
* This is needed for PHP4 compatibility, it will
* call the constructor, when a new instance is created.
* @param string $srcenc source charset encoding, use NULL (default) to use
* whatever the document specifies
* @param string $mode how this parser object should work, "event" for
* startelement/endelement-type events, "func"
* to have it call functions named after elements
* @param string $tgenc a valid target encoding
function XML_Parser($srcenc = null, $mode = 'event', $tgtenc = null)
XML_Parser::__construct($srcenc, $mode, $tgtenc);
* PHP5 constructor
function __construct($srcenc = null, $mode = 'event', $tgtenc = null)
$this->PEAR('XML_Parser_Error');
$this->mode = $mode;
$this->srcenc = $srcenc;
$this->tgtenc = $tgtenc;
* Sets the mode of the parser.
* Possible modes are:
* - func
* - event
* You can set the mode using the second parameter
* in the constructor.
* This method is only needed, when switching to a new
* mode at a later point.
* @access public
* @param string mode, either 'func' or 'event'
* @return boolean|object true on success, PEAR_Error otherwise
function setMode($mode)
if ($mode != 'func' && $mode != 'event') {
$this->raiseError('Unsupported mode given', XML_PARSER_ERROR_UNSUPPORTED_MODE);
return true;
* Sets the object, that will handle the XML events
* This allows you to create a handler object independent of the
* parser object that you are using and easily switch the underlying
* parser.
* If no object will be set, XML_Parser assumes that you
* extend this class and handle the events in $this.
* @access public
* @param object object to handle the events
* @return boolean will always return true
* @since v1.2.0beta3
function setHandlerObj(&$obj)
$this->_handlerObj = &$obj;
return true;
* Init the element handlers
* @access private
function _initHandlers()
if (!is_resource($this->parser)) {
return false;
if (!is_object($this->_handlerObj)) {
$this->_handlerObj = &$this;
switch ($this->mode) {
case 'func':
xml_set_object($this->parser, $this);
xml_set_element_handler($this->parser, 'funcStartHandler', 'funcEndHandler');
break;
case 'event':
xml_set_object($this->parser, $this->_handlerObj);
xml_set_element_handler($this->parser, 'startHandler', 'endHandler');
break;
default:
return $this->raiseError('Unsupported mode given', XML_PARSER_ERROR_UNSUPPORTED_MODE);
break;
* set additional handlers for character data, entities, etc.
foreach ($this->handler as $xml_func => $method) {
if (method_exists($this->_handlerObj, $method)) {
$xml_func = 'xml_set_' . $xml_func;
$xml_func($this->parser, $method);
// {{{ _create()
* create the XML parser resource
* Has been moved from the constructor to avoid
* problems with object references.
* Furthermore it allows us returning an error
* if something fails.
* @access private
function _create()
if ($this->srcenc === null) {
$xp = @xml_parser_create();
} else {
$xp = @xml_parser_create($this->srcenc);
if (is_resource($xp)) {
if ($this->tgtenc !== null) {
if (!@xml_parser_set_option($xp, XML_OPTION_TARGET_ENCODING,
$this->tgtenc)) {
return $this->raiseError('invalid target encoding', XML_PARSER_ERROR_INVALID_ENCODING);
$this->parser = $xp;
$result = $this->_initHandlers($this->mode);
if ($this->isError($result)) {
return $result;
xml_parser_set_option($xp, XML_OPTION_CASE_FOLDING, $this->folding);
return true;
return $this->raiseError('Unable to create XML parser resource.', XML_PARSER_ERROR_NO_RESOURCE);
// {{{ reset()
* Reset the parser.
* This allows you to use one parser instance
* to parse multiple XML documents.
* @access public
function reset()
$result = $this->_create();
if ($this->isError( $result )) {
return $result;
// {{{ setInputFile()
* Sets the input xml file to be parsed
* @param string Filename (full path)
* @return resource fopen handle of the given file
* @throws XML_Parser_Error
* @see setInput(), setInputString(), parse()
* @access public
function setInputFile($file)
* check, if file is a remote file
if (eregi('^(http|ftp)://', substr($file, 0, 10))) {
if (!ini_get('safe_mode')) {
ini_set('allow_url_fopen', 1);
} else {
return $this->raiseError('Remote files cannot be parsed, as safe mode is enabled.', XML_PARSER_ERROR_REMOTE);
$fp = @fopen($file, 'rb');
if (is_resource($fp)) {
$this->fp = $fp;
return $fp;
return $this->raiseError('File could not be opened.', XML_PARSER_ERROR_FILE_NOT_READABLE);
// {{{ setInputString()
* XML_Parser::setInputString()
* Sets the xml input from a string
* @param string $data a string containing the XML document
* @return null
function setInputString($data)
$this->fp = $data;
return null;
// {{{ setInput()
* Sets the file handle to use with parse().
* You should use setInputFile() or setInputString() if you
* pass a string
* @param mixed $fp Can be either a resource returned from fopen(),
* a URL, a local filename or a string.
* @access public
* @see parse()
* @uses setInputString(), setInputFile()
function setInput($fp)
$this->fp = $fp;
return true;
// see if it's an absolute URL (has a scheme at the beginning)
elseif (eregi('^[a-z]+://', substr($fp, 0, 10))) {
return $this->setInputFile($fp);
// see if it's a local file
elseif (file_exists($fp)) {
// it must be a string
else {
$this->fp = $fp;
return true;
return $this->raiseError('Illegal input format', XML_PARSER_ERROR_INVALID_INPUT);
// {{{ parse()
* Central parsing function.
* @return true|object PEAR error returns true on success, or a PEAR_Error otherwise
* @access public
function parse()
* reset the parser
$result = $this->reset();
return $result;
// if $this->fp was fopened previously
if (is_resource($this->fp)) {
while ($data = fread($this->fp, 4096)) {
if (!$this->_parseString($data, feof($this->fp))) {
return $this->raiseError();
// otherwise, $this->fp must be a string
} else {
if (!$this->_parseString($this->fp, true)) {
$this->free();
return true;
* XML_Parser::_parseString()
* @param boolean $eof
* @return bool
* @access private
* @see parseString()
function _parseString($data, $eof = false)
return xml_parse($this->parser, $data, $eof);
// {{{ parseString()
* XML_Parser::parseString()
* Parses a string.
* @param string $data XML data
* @param boolean $eof If set and TRUE, data is the last piece of data sent in this parser
* @return Pear Error|true true on success or a PEAR Error
* @see _parseString()
function parseString($data, $eof = false)
if (!isset($this->parser) || !is_resource($this->parser)) {
$this->reset();
if (!$this->_parseString($data, $eof)) {
if ($eof === true) {
$this->free();
return true;
* XML_Parser::free()
* Free the internal resources associated with the parser
* @return null
function free()
if (is_resource($this->parser)) {
xml_parser_free($this->parser);
unset( $this->parser );
if (isset($this->fp) && is_resource($this->fp)) {
fclose($this->fp);
unset($this->fp);
return null;
* XML_Parser::raiseError()
* Trows a XML_Parser_Error and free's the internal resources
* @param string $msg the error message
* @param integer $ecode the error message code
* @return XML_Parser_Error
function raiseError($msg = null, $ecode = 0)
$msg = !is_null($msg) ? $msg : $this->parser;
$err = &new XML_Parser_Error($msg, $ecode);
$this->free();
return parent::raiseError($err);
// {{{ funcStartHandler()
function funcStartHandler($xp, $elem, $attribs)
$func = 'xmltag_' . $elem;
if (method_exists($this->_handlerObj, $func)) {
call_user_func(array(&$this->_handlerObj, $func), $xp, $elem, $attribs);
// {{{ funcEndHandler()
function funcEndHandler($xp, $elem)
$func = 'xmltag_' . $elem . '_';
call_user_func(array(&$this->_handlerObj, $func), $xp, $elem);
* @abstract
function startHandler($xp, $elem, &$attribs)
return NULL;
// {{{ endHandler()
* @abstract
function endHandler($xp, $elem)
return NULL;
// }}}me
* error class, replaces PEAR_Error
* An instance of this class will be returned
* if an error occurs inside XML_Parser.
* There are three advantages over using the standard PEAR_Error:
* - All messages will be prefixed
* - check for XML_Parser error, using is_a( $error, 'XML_Parser_Error' )
* - messages can be generated from the xml_parser resource
* @access public
* @see PEAR_Error
class XML_Parser_Error extends PEAR_Error
// {{{ properties
* prefix for all messages
* @var string
var $error_message_prefix = 'XML_Parser: ';
// {{{ constructor()
* construct a new error instance
* You may either pass a message or an xml_parser resource as first
* parameter. If a resource has been passed, the last error that
* happened will be retrieved and returned.
* @access public
* @param string|resource message or parser resource
* @param integer error code
* @param integer error handling
* @param integer error level
function XML_Parser_Error($msgorparser = 'unknown error', $code = 0, $mode = PEAR_ERROR_RETURN, $level = E_USER_NOTICE)
if (is_resource($msgorparser)) {
$code = xml_get_error_code($msgorparser);
$msgorparser = sprintf('%s at XML input line %d',
xml_error_string($code),
xml_get_current_line_number($msgorparser));
$this->PEAR_Error($msgorparser, $code, $mode, $level);
--- NEW FILE: rss-icon.gif ---
(This appears to be a binary file; contents omitted.)
More information about the grass-web
