[GRASSweb-list] markus: web parser.php, NONE, 1.1 pear.php, NONE, 1.1 rss-icon.gif, NONE, 1.1 rss.php, NONE, 1.1 main.inc, 1.78, 1.79 newsarchive.html, 1.49, 1.50 rss.xml, 1.8, 1.9
grass at intevation.de grass at intevation.de
Tue Oct 31 17:25:21 EST 2006
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv25970
Modified Files:
	main.inc newsarchive.html rss.xml
Added Files:
	parser.php pear.php rss-icon.gif rss.php
Log Message:
work around PHP bug
--- NEW FILE: parser.php ---
<?php
// | PHP Version 4                                                        |
// | Copyright (c) 1997-2004 The PHP Group                                |
// | This source file is subject to version 3.0 of the PHP license,       |
// | that is bundled with this package in the file LICENSE, and is        |
// | available at through the world-wide-web at                           |
// | http://www.php.net/license/3_0.txt.                                  |
// | If you did not receive a copy of the PHP license and are unable to   |
// | obtain it through the world-wide-web, please send a note to          |
// | license at php.net so we can mail you a copy immediately.               |
// | Author: Stig Bakken <ssb at fast.no>                                    |
// |         Tomas V.V.Cox <cox at idecnet.com>                              |
// |         Stephan Schmidt <schst at php-tools.net>                        |
// $Id: parser.php,v 1.1 2006/10/31 22:25:18 markus Exp $
 * XML Parser class.
 * This is an XML parser based on PHP's "xml" extension,
 * based on the bundled expat library.
 * @category XML
 * @package XML_Parser
 * @author  Stig Bakken <ssb at fast.no>
 * @author  Tomas V.V.Cox <cox at idecnet.com>
 * @author  Stephan Schmidt <schst at php-tools.net>
 * uses PEAR's error handling
require_once 'pear.php';
 * resource could not be created
define('XML_PARSER_ERROR_NO_RESOURCE', 200);
 * unsupported mode
define('XML_PARSER_ERROR_UNSUPPORTED_MODE', 201);
 * invalid encoding was given
define('XML_PARSER_ERROR_INVALID_ENCODING', 202);
 * specified file could not be read
define('XML_PARSER_ERROR_FILE_NOT_READABLE', 203);
 * invalid input
define('XML_PARSER_ERROR_INVALID_INPUT', 204);
 * remote file cannot be retrieved in safe mode
define('XML_PARSER_ERROR_REMOTE', 205);
 * XML Parser class.
 * Notes:
 * - It requires PHP 4.0.4pl1 or greater
 * - From revision 1.17, the function names used by the 'func' mode
 *   are in the format "xmltag_$elem", for example: use "xmltag_name"
 *   to handle the <name></name> tags of your xml file.
 * @category XML
 * @todo    create XML_Parser_Namespace to parse documents with namespaces
 * @todo    create XML_Parser_Pull
 * @todo    Tests that need to be made:
 *          - mixing character encodings
 *          - a test using all expat handlers
 *          - options (folding, output charset)
 *          - different parsing modes
class XML_Parser extends PEAR
    // {{{ properties
     * XML parser handle
     * @var  resource
     * @see  xml_parser_create()
    var $parser;
     * File handle if parsing from a file
     * @var  resource
    var $fp;
     * Whether to do case folding
     * If set to true, all tag and attribute names will
     * be converted to UPPER CASE.
     * @var  boolean
    var $folding = true;
     * Mode of operation, one of "event" or "func"
     * @var  string
    var $mode;
     * Mapping from expat handler function to class method.
     * @var  array
    var $handler = array(
        'character_data_handler'            => 'cdataHandler',
        'default_handler'                   => 'defaultHandler',
        'processing_instruction_handler'    => 'piHandler',
        'unparsed_entity_decl_handler'      => 'unparsedHandler',
        'notation_decl_handler'             => 'notationHandler',
        'external_entity_ref_handler'       => 'entityrefHandler'
     * source encoding
     * @var string
    var $srcenc;
     * target encoding
     * @var string
    var $tgtenc;
     * handler object
     * @var object
    var $_handlerObj;
    // {{{ constructor
     * Creates an XML parser.
     * This is needed for PHP4 compatibility, it will
     * call the constructor, when a new instance is created.
     * @param string $srcenc source charset encoding, use NULL (default) to use
     *                       whatever the document specifies
     * @param string $mode   how this parser object should work, "event" for
     *                       startelement/endelement-type events, "func"
     *                       to have it call functions named after elements
     * @param string $tgenc  a valid target encoding
    function XML_Parser($srcenc = null, $mode = 'event', $tgtenc = null)
        XML_Parser::__construct($srcenc, $mode, $tgtenc);
     * PHP5 constructor
    function __construct($srcenc = null, $mode = 'event', $tgtenc = null)
        $this->PEAR('XML_Parser_Error');
        $this->mode   = $mode;
        $this->srcenc = $srcenc;
        $this->tgtenc = $tgtenc;
     * Sets the mode of the parser.
     * Possible modes are:
     * - func
     * - event
     * You can set the mode using the second parameter
     * in the constructor.
     * This method is only needed, when switching to a new
     * mode at a later point.
     * @access  public
     * @param   string          mode, either 'func' or 'event'
     * @return  boolean|object  true on success, PEAR_Error otherwise
    function setMode($mode)
        if ($mode != 'func' && $mode != 'event') {
            $this->raiseError('Unsupported mode given', XML_PARSER_ERROR_UNSUPPORTED_MODE);
        return true;
     * Sets the object, that will handle the XML events
     * This allows you to create a handler object independent of the
     * parser object that you are using and easily switch the underlying
     * parser.
     * If no object will be set, XML_Parser assumes that you
     * extend this class and handle the events in $this.
     * @access  public
     * @param   object      object to handle the events
     * @return  boolean     will always return true
     * @since   v1.2.0beta3
    function setHandlerObj(&$obj)
        $this->_handlerObj = &$obj;
        return true;
     * Init the element handlers
     * @access  private
    function _initHandlers()
        if (!is_resource($this->parser)) {
            return false;
        if (!is_object($this->_handlerObj)) {
            $this->_handlerObj = &$this;
        switch ($this->mode) {
            case 'func':
                xml_set_object($this->parser, $this);
                xml_set_element_handler($this->parser, 'funcStartHandler', 'funcEndHandler');
                break;
            case 'event':
                xml_set_object($this->parser, $this->_handlerObj);
                xml_set_element_handler($this->parser, 'startHandler', 'endHandler');
                break;
            default:
                return $this->raiseError('Unsupported mode given', XML_PARSER_ERROR_UNSUPPORTED_MODE);
                break;
         * set additional handlers for character data, entities, etc.
        foreach ($this->handler as $xml_func => $method) {
            if (method_exists($this->_handlerObj, $method)) {
                $xml_func = 'xml_set_' . $xml_func;
                $xml_func($this->parser, $method);
    // {{{ _create()
     * create the XML parser resource
     * Has been moved from the constructor to avoid
     * problems with object references.
     * Furthermore it allows us returning an error
     * if something fails.
     * @access   private
    function _create()
        if ($this->srcenc === null) {
            $xp = @xml_parser_create();
        } else {
            $xp = @xml_parser_create($this->srcenc);
        if (is_resource($xp)) {
            if ($this->tgtenc !== null) {
                if (!@xml_parser_set_option($xp, XML_OPTION_TARGET_ENCODING,
                                            $this->tgtenc)) {
                    return $this->raiseError('invalid target encoding', XML_PARSER_ERROR_INVALID_ENCODING);
            $this->parser = $xp;
            $result = $this->_initHandlers($this->mode);
            if ($this->isError($result)) {
                return $result;
            xml_parser_set_option($xp, XML_OPTION_CASE_FOLDING, $this->folding);
            return true;
        return $this->raiseError('Unable to create XML parser resource.', XML_PARSER_ERROR_NO_RESOURCE);
    // {{{ reset()
     * Reset the parser.
     * This allows you to use one parser instance
     * to parse multiple XML documents.
     * @access   public
    function reset()
        $result = $this->_create();
        if ($this->isError( $result )) {
            return $result;
    // {{{ setInputFile()
     * Sets the input xml file to be parsed
     * @param    string      Filename (full path)
     * @return   resource    fopen handle of the given file
     * @throws   XML_Parser_Error
     * @see      setInput(), setInputString(), parse()
     * @access   public
    function setInputFile($file)
         * check, if file is a remote file
        if (eregi('^(http|ftp)://', substr($file, 0, 10))) {
            if (!ini_get('safe_mode')) {
                ini_set('allow_url_fopen', 1);
            } else {
                return $this->raiseError('Remote files cannot be parsed, as safe mode is enabled.', XML_PARSER_ERROR_REMOTE);
        $fp = @fopen($file, 'rb');
        if (is_resource($fp)) {
            $this->fp = $fp;
            return $fp;
        return $this->raiseError('File could not be opened.', XML_PARSER_ERROR_FILE_NOT_READABLE);
    // {{{ setInputString()
     * XML_Parser::setInputString()
     * Sets the xml input from a string
     * @param string $data a string containing the XML document
     * @return null
    function setInputString($data)
        $this->fp = $data;
        return null;
    // {{{ setInput()
     * Sets the file handle to use with parse().
     * You should use setInputFile() or setInputString() if you
     * pass a string
     * @param    mixed  $fp  Can be either a resource returned from fopen(),
     *                       a URL, a local filename or a string.
     * @access   public
     * @see      parse()
     * @uses     setInputString(), setInputFile()
    function setInput($fp)
            $this->fp = $fp;
            return true;
        // see if it's an absolute URL (has a scheme at the beginning)
        elseif (eregi('^[a-z]+://', substr($fp, 0, 10))) {
            return $this->setInputFile($fp);
        // see if it's a local file
        elseif (file_exists($fp)) {
        // it must be a string
        else {
            $this->fp = $fp;
            return true;
        return $this->raiseError('Illegal input format', XML_PARSER_ERROR_INVALID_INPUT);
    // {{{ parse()
     * Central parsing function.
     * @return   true|object PEAR error     returns true on success, or a PEAR_Error otherwise
     * @access   public
    function parse()
         * reset the parser
        $result = $this->reset();
            return $result;
        // if $this->fp was fopened previously
        if (is_resource($this->fp)) {
            while ($data = fread($this->fp, 4096)) {
                if (!$this->_parseString($data, feof($this->fp))) {
                    return $this->raiseError();
        // otherwise, $this->fp must be a string
        } else {
            if (!$this->_parseString($this->fp, true)) {
        $this->free();
        return true;
     * XML_Parser::_parseString()
     * @param boolean $eof
     * @return bool
     * @access private
     * @see parseString()
    function _parseString($data, $eof = false)
        return xml_parse($this->parser, $data, $eof);
    // {{{ parseString()
     * XML_Parser::parseString()
     * Parses a string.
     * @param    string  $data XML data
     * @param    boolean $eof  If set and TRUE, data is the last piece of data sent in this parser
     * @return   Pear Error|true   true on success or a PEAR Error
     * @see      _parseString()
    function parseString($data, $eof = false)
        if (!isset($this->parser) || !is_resource($this->parser)) {
            $this->reset();
        if (!$this->_parseString($data, $eof)) {
        if ($eof === true) {
            $this->free();
        return true;
     * XML_Parser::free()
     * Free the internal resources associated with the parser
     * @return null
    function free()
        if (is_resource($this->parser)) {
            xml_parser_free($this->parser);
            unset( $this->parser );
        if (isset($this->fp) && is_resource($this->fp)) {
            fclose($this->fp);
        unset($this->fp);
        return null;
     * XML_Parser::raiseError()
     * Trows a XML_Parser_Error and free's the internal resources
     * @param string  $msg   the error message
     * @param integer $ecode the error message code
     * @return XML_Parser_Error
    function raiseError($msg = null, $ecode = 0)
        $msg = !is_null($msg) ? $msg : $this->parser;
        $err = &new XML_Parser_Error($msg, $ecode);
        $this->free();
        return parent::raiseError($err);
    // {{{ funcStartHandler()
    function funcStartHandler($xp, $elem, $attribs)
        $func = 'xmltag_' . $elem;
        if (method_exists($this->_handlerObj, $func)) {
            call_user_func(array(&$this->_handlerObj, $func), $xp, $elem, $attribs);
    // {{{ funcEndHandler()
    function funcEndHandler($xp, $elem)
        $func = 'xmltag_' . $elem . '_';
            call_user_func(array(&$this->_handlerObj, $func), $xp, $elem);
    // {{{ startHandler()
     * @abstract
    function startHandler($xp, $elem, &$attribs)
        return NULL;
    // {{{ endHandler()
     * @abstract
    function endHandler($xp, $elem)
        return NULL;
    // }}}me
 * error class, replaces PEAR_Error
 * An instance of this class will be returned
 * if an error occurs inside XML_Parser.
 * There are three advantages over using the standard PEAR_Error:
 * - All messages will be prefixed
 * - check for XML_Parser error, using is_a( $error, 'XML_Parser_Error' )
 * - messages can be generated from the xml_parser resource
 * @access  public
 * @see     PEAR_Error
class XML_Parser_Error extends PEAR_Error
    // {{{ properties
    * prefix for all messages
    * @var      string
    var $error_message_prefix = 'XML_Parser: ';
    // {{{ constructor()
    * construct a new error instance
    * You may either pass a message or an xml_parser resource as first
    * parameter. If a resource has been passed, the last error that
    * happened will be retrieved and returned.
    * @access   public
    * @param    string|resource     message or parser resource
    * @param    integer             error code
    * @param    integer             error handling
    * @param    integer             error level
    function XML_Parser_Error($msgorparser = 'unknown error', $code = 0, $mode = PEAR_ERROR_RETURN, $level = E_USER_NOTICE)
        if (is_resource($msgorparser)) {
            $code = xml_get_error_code($msgorparser);
            $msgorparser = sprintf('%s at XML input line %d',
                                   xml_error_string($code),
                                   xml_get_current_line_number($msgorparser));
        $this->PEAR_Error($msgorparser, $code, $mode, $level);
--- NEW FILE: pear.php ---
<?php
// | PEAR, the PHP Extension and Application Repository                 |
// | available through the world-wide-web at the following url:         |
// | Authors: Sterling Hughes <sterling at php.net>                        |
// |          Stig Bakken <ssb at php.net>                                 |
[...1017 lines suppressed...]
        return sprintf('[%s: message="%s" code=%d mode=%s level=%s '.
                       'prefix="%s" info="%s"]',
                       strtolower(get_class($this)), $this->message, $this->code,
                       implode("|", $modes), $levels[$this->level],
                       $this->error_message_prefix,
                       $this->userinfo);
 * Local Variables:
 * mode: php
 * tab-width: 4
 * c-basic-offset: 4
 * End:
--- NEW FILE: rss-icon.gif ---
(This appears to be a binary file; contents omitted.)
--- NEW FILE: rss.php ---
<?php
// vim: set expandtab tabstop=4 shiftwidth=4 fdm=marker:
// | Copyright (c) 1997-2003 The PHP Group                                |
// | This source file is subject to version 2.02 of the PHP license,      |
// | http://www.php.net/license/2_02.txt.                                 |
// | Authors: Martin Jansen <mj at php.net>                                  |
// $Id: rss.php,v 1.1 2006/10/31 22:25:18 markus Exp $
require_once 'parser.php';
* RSS parser class.
* This class is a parser for Resource Description Framework (RDF) Site
* Summary (RSS) documents. For more information on RSS see the
* website of the RSS working group (http://www.purl.org/rss/).
* @author Martin Jansen <mj at php.net>
* @version $Revision: 1.1 $
* @access  public
class XML_RSS extends XML_Parser
    // {{{ properties
     * @var string
    var $insideTag = '';
     * @var string
    var $activeTag = '';
     * @var array
    var $channel = array();
     * @var array
    var $items = array();
     * @var array
    var $item = array();
     * @var array
    var $image = array();
     * @var array
    var $textinput = array();
     * @var array
    var $textinputs = array();
     * @var array
    var $parentTags = array('CHANNEL', 'ITEM', 'IMAGE', 'TEXTINPUT');
     * @var array
    var $channelTags = array('TITLE', 'LINK', 'DESCRIPTION', 'IMAGE',
                              'ITEMS', 'TEXTINPUT');
     * @var array
    var $itemTags = array('TITLE', 'LINK', 'DESCRIPTION', 'PUBDATE');
     * @var array
    var $imageTags = array('TITLE', 'URL', 'LINK');
    var $textinputTags = array('TITLE', 'DESCRIPTION', 'NAME', 'LINK');
     * List of allowed module tags
     * Currently Dublin Core Metadata and the blogChannel RSS module
     * are supported.
     * @var array
    var $moduleTags = array('DC:TITLE', 'DC:CREATOR', 'DC:SUBJECT', 'DC:DESCRIPTION',
                            'DC:PUBLISHER', 'DC:CONTRIBUTOR', 'DC:DATE', 'DC:TYPE',
                            'DC:FORMAT', 'DC:IDENTIFIER', 'DC:SOURCE', 'DC:LANGUAGE',
                            'DC:RELATION', 'DC:COVERAGE', 'DC:RIGHTS',
                            'BLOGCHANNEL:BLOGROLL', 'BLOGCHANNEL:MYSUBSCRIPTIONS',
                            'BLOGCHANNEL:MYSUBSCRIPTIONS', 'BLOGCHANNEL:CHANGES');
    // {{{ Constructor
     * Constructor
     * @access public
     * @param mixed File pointer or name of the RDF file.
     * @return void
    function XML_RSS($handle = '')
        $this->XML_Parser();
        if (@is_resource($handle)) {
            $this->setInput($handle);
        } elseif ($handle != '') {
            $this->setInputFile($handle);
        } else {
            $this->raiseError('No filename passed.');
     * Start element handler for XML parser
     * @access private
     * @param  object XML parser object
     * @param  string XML element
     * @param  array  Attributes of XML tag
     * @return void
    function startHandler($parser, $element, $attribs)
        switch ($element) {
            case 'CHANNEL':
            case 'ITEM':
            case 'IMAGE':
            case 'TEXTINPUT':
                $this->insideTag = $element;
                break;
            default:
                $this->activeTag = $element;
    // {{{ endHandler()
     * End element handler for XML parser
     * If the end of <item>, <channel>, <image> or <textinput>
     * is reached, this function updates the structure array
     * $this->struct[] and adds the field "type" to this array,
     * that defines the type of the current field.
     * @access private
     * @param  string
     * @return void
    function endHandler($parser, $element)
        if ($element == $this->insideTag) {
            $this->insideTag = '';
            $this->struct[] = array_merge(array('type' => strtolower($element)),
                                          $this->last);
        if ($element == 'ITEM') {
            $this->items[] = $this->item;
            $this->item = '';
        if ($element == 'IMAGE') {
            $this->images[] = $this->image;
            $this->image = '';
        if ($element == 'TEXTINPUT') {
            $this->textinputs = $this->textinput;
            $this->textinput = '';
        $this->activeTag = '';
    // {{{ cdataHandler()
     * Handler for character data
     * @access private
     * @param  string CDATA
     * @return void
    function cdataHandler($parser, $cdata)
        if (in_array($this->insideTag, $this->parentTags)) {
            $tagName = strtolower($this->insideTag);
            $var = $this->{$tagName . 'Tags'};
            if (in_array($this->activeTag, $var) ||
                in_array($this->activeTag, $this->moduleTags)) {
                $this->_add($tagName, strtolower($this->activeTag),
                            $cdata);
    // {{{ defaultHandler()
     * Default handler for XML parser
     * @access private
     * @return void
    function defaultHandler($parser, $cdata)
        return;
    // {{{ _add()
     * Add element to internal result sets
     * @access private
     * @param  string Name of the result set
     * @param  string Fieldname
     * @param  string Value
     * @return void
     * @see    cdataHandler
    function _add($type, $field, $value)
        if (empty($this->{$type}) || empty($this->{$type}[$field])) {
            $this->{$type}[$field] = $value;
        } else {
            $this->{$type}[$field] .= $value;
        $this->last = $this->{$type};
    // {{{ getStructure()
     * Get complete structure of RSS file
     * @access public
     * @return array
    function getStructure()
        return (array)$this->struct;
    // {{{ getchannelInfo()
     * Get general information about current channel
     * This function returns an array containing the information
     * that has been extracted from the <channel>-tag while parsing
     * the RSS file.
     * @access public
     * @return array
    function getChannelInfo()
        return (array)$this->channel;
    // {{{ getItems()
     * Get items from RSS file
     * This function returns an array containing the set of items
     * that are provided by the RSS file.
     * @access public
     * @return array
    function getItems()
        return (array)$this->items;
    // {{{ getImages()
     * Get images from RSS file
     * This function returns an array containing the set of images
     * @access public
     * @return array
    function getImages()
        return (array)$this->images;
    // {{{ getTextinputs()
     * Get text input fields from RSS file
     * @access public
     * @return array
    function getTextinputs()
        return (array)$this->textinputs;
Index: main.inc
RCS file: /grassrepository/web/main.inc,v
retrieving revision 1.78
retrieving revision 1.79
diff -u -d -r1.78 -r1.79
--- main.inc	31 Oct 2006 11:29:32 -0000	1.78
+++ main.inc	31 Oct 2006 22:25:18 -0000	1.79
@@ -51,12 +51,12 @@
    <!-- MAIN: NEWS SECTION -->
    <center>
    <h4>Latest News!
-   <a href="http://grass.itc.it/rss.xml"><img src="feed/rss-icon.gif" alt="RSS Feed" border=0></a></h4>
+   <a href="http://grass.itc.it/rss.xml"><img src="rss-icon.gif" alt="RSS Feed" border=0></a></h4>
     </center>
   <ul>
    <?php
-   include("feed/rss.php"); // we'd better hardcode the URL ?
+   include("rss.php");
    $r1 =& new XML_RSS('rss.xml');
    $r1->parse();
    foreach ($r1->getItems() as $value) {
Index: newsarchive.html
RCS file: /grassrepository/web/newsarchive.html,v
retrieving revision 1.49
retrieving revision 1.50
diff -u -d -r1.49 -r1.50
--- newsarchive.html	31 Oct 2006 12:53:44 -0000	1.49
+++ newsarchive.html	31 Oct 2006 22:25:18 -0000	1.50
@@ -11,7 +11,7 @@
 <CENTER><h3>GRASS News Archive</h3></CENTER>
- [ <a href="http://grass.itc.it/rss.xml"><img src="feed/rss-icon.gif" alt="RSS Feed" border="0"></a> |
+ [ <a href="http://grass.itc.it/rss.xml"><img src="rss-icon.gif" alt="RSS Feed" border="0"></a> |
    See also: <a href="press.html">GRASS in the Press</a> ]
 <ul>
Index: rss.xml
RCS file: /grassrepository/web/rss.xml,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- rss.xml	31 Oct 2006 20:13:33 -0000	1.8
+++ rss.xml	31 Oct 2006 22:25:18 -0000	1.9
@@ -1,5 +1,5 @@
 <?xml version="1.0" encoding="ISO-8859-1"?>
-<?xml-stylesheet type="text/css" href="feed/grass_rss_style.css" ?>
+<?xml-stylesheet type="text/css" href="grass_rss_style.css" ?>
 <rss version="0.91">
   <channel>
     <title>Geographic Resources Analysis Support System</title>
More information about the grass-web mailing list
