[GRASSweb-list] markus: web/announces announce_grass630.html, 1.1, 1.2
grass at intevation.de grass at intevation.de
Tue Feb 13 03:17:30 EST 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv27796
Modified Files:
Log Message:
fix; r.profile
Index: announce_grass630.html
RCS file: /grassrepository/web/announces/announce_grass630.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- announce_grass630.html	12 Feb 2007 23:23:51 -0000	1.1
+++ announce_grass630.html	13 Feb 2007 08:17:27 -0000	1.2
@@ -124,7 +124,7 @@
 <ul>
  <li>Source code quality/libraries:
  <ul>
-  <li> Mayn ported fixes for native support on MS-Windows (MinGW based)
+  <li> Many fixes for native support on MS-Windows (MinGW based)
   <li> <a href="http://grass.itc.it/devel/index.php#prog">Programmer's Manual</a>:
        continued Doxygen integration and automated generation into PDF and HTML
        formats. Publicly available for download and perusal.
@@ -192,6 +192,7 @@
  <li> <b>r.out.gdal</b>: <font color=red>NEW</font> - new C implementation, region sensitive, with color export if present
  <li> <b>r.out.vrml</b>: formerly called p.out.vrml
  <li> <b>r.out.xyz</b>: <font color=red>NEW</font> - export a raster map as x,y,z, to a text file
+ <li> <b>r.profile</b>: don't report data outside of current region
  <li> <b>r.proj</b>: Fix cubic interpolation equation
  <li> <b>r.proj.seg</b>: improved implementation of r.proj for large raster maps (to substitute r.proj)
  <li> <b>r.resamp.interp</b>: <font color=red>NEW</font> - Resamples raster map layers using interpolation
More information about the grass-web mailing list
