[GRASSweb-list] markus: web newsarchive.html, 1.52, 1.53 rss.xml,
1.16, 1.17
grass at intevation.de
Tue Feb 13 08:54:28 EST 2007
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv4493
Modified Files:
newsarchive.html rss.xml
Log Message:
news section cleanup
Index: newsarchive.html
RCS file: /grassrepository/web/newsarchive.html,v
retrieving revision 1.52
retrieving revision 1.53
diff -u -d -r1.52 -r1.53
--- newsarchive.html 16 Jan 2007 13:07:05 -0000 1.52
+++ newsarchive.html 13 Feb 2007 13:54:26 -0000 1.53
@@ -15,6 +15,8 @@
See also: <a href="press.html">GRASS in the Press</a> ]
<ul>
+<li>06 Dec 2006: <a href="http://grass.itc.it/grass62/source/"><strong>
+GRASS 6.2.1RC1 released</strong></a> - This release fixes several bugs discovered in the 6.2.0 source code</li>
<li>31 Oct 2006: <a href="http://grass.itc.it/announces/announce_grass620.html"><strong>
GRASS 6.2.0 released</strong></a> - The stable version is published: Source code available now, packaged installers
for major platforms are currently being built and will follow shortly</li>
Index: rss.xml
RCS file: /grassrepository/web/rss.xml,v
retrieving revision 1.16
retrieving revision 1.17
diff -u -d -r1.16 -r1.17
--- rss.xml 12 Feb 2007 20:23:04 -0000 1.16
+++ rss.xml 13 Feb 2007 13:54:26 -0000 1.17
@@ -52,13 +52,5 @@
<guid>http://grass.itc.it/grass62/</guid>
</item>
- <item>
- <title>GRASS 6.2.1RC1 released</title>
- <link>http://grass.itc.it/grass62/source/</link>
- <description>This release fixes several bugs discovered in the 6.2.0 source code</description>
- <pubDate>Tue, 06 Dec 2006 22:44:49 GMT</pubDate>
- <guid>http://grass.itc.it/grass62/</guid>
- </item>
</channel>
</rss>
More information about the grass-web
