[GRASSweb-list] markus: web/announces announce_grass630.html, 1.4,
	1.5
    grass at intevation.de
    Tue Feb 13 17:22:56 EST 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv17446
Modified Files:
Log Message:
typos
Index: announce_grass630.html
RCS file: /grassrepository/web/announces/announce_grass630.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- announce_grass630.html	13 Feb 2007 17:44:15 -0000	1.4
+++ announce_grass630.html	13 Feb 2007 22:22:54 -0000	1.5
@@ -192,12 +192,12 @@
  <li> <b>r.bilinear</b>: This module is deprecated. Please use 'r.stats.interp' instead.
  <li> <b>r.colors</b>: new predefined color tables added
  <li> <b>r.flow</b>: 3d length fix and 64bit crash fix
- <li> <b>r.gwflow</b>: <font color=red>NEW</font> - confined and unconfied groundwater flow in 2D
+ <li> <b>r.gwflow</b>: <font color=red>NEW</font> - confined and unconfined groundwater flow in 2D
  <li> <b>r.in.srtm</b>: added PIXELTYPE SIGNEDINT to header file for r.in.gdal to recognize negative values (SRTM etc)
  <li> <b>r.in.wms</b>: various fixes
  <li> <b>r.le.*</b>: various updates to GRASS 6
  <li> <b>r.li.*</b>: new landscape structure analysis suite
- <li> <b>r.out.gdal</b>: <font color=red>NEW</font> - new C implementation, region sensitive, with color export if present
+ <li> <b>r.out.gdal</b>: <font color=red>NEW</font> - now C implementation, region sensitive, with color export if present
  <li> <b>r.out.vrml</b>: formerly called p.out.vrml
  <li> <b>r.out.xyz</b>: <font color=red>NEW</font> - export a raster map as x,y,z, to a text file
  <li> <b>r.profile</b>: don't report data outside of current region
More information about the grass-web
