[GRASSweb-list] markus: web/announces announce_grass630.html, 1.5, 1.6
grass at intevation.de grass at intevation.de
Wed Feb 28 16:34:11 EST 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv7433
Modified Files:
Log Message:
driver updates
Index: announce_grass630.html
RCS file: /grassrepository/web/announces/announce_grass630.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- announce_grass630.html	13 Feb 2007 22:22:54 -0000	1.5
+++ announce_grass630.html	28 Feb 2007 21:34:09 -0000	1.6
@@ -166,6 +166,12 @@
  <li> major clean-up to the display architecture (libraries and drivers): the drivers no longer maintain a palette; all colours are specified directly as R/G/B values.
 </ul>
+<li> Drivers:
+<ul>
+ <li> DBF driver: drop column support, TIME type support
+ <li> display driver: major cleanup
+</ul>
 <li> Modules/Scripts:
 <ul>
  <li> Message translation (i18N): translations continued, new language Vietnamese, Arabic
@@ -196,7 +202,7 @@
  <li> <b>r.in.srtm</b>: added PIXELTYPE SIGNEDINT to header file for r.in.gdal to recognize negative values (SRTM etc)
  <li> <b>r.in.wms</b>: various fixes
  <li> <b>r.le.*</b>: various updates to GRASS 6
- <li> <b>r.li.*</b>: new landscape structure analysis suite
+ <li> <b>r.li.*</b>: <font color=red>NEW</font> - landscape structure analysis suite (single and multiprocessor implementation)
  <li> <b>r.out.gdal</b>: <font color=red>NEW</font> - now C implementation, region sensitive, with color export if present
  <li> <b>r.out.vrml</b>: formerly called p.out.vrml
  <li> <b>r.out.xyz</b>: <font color=red>NEW</font> - export a raster map as x,y,z, to a text file
More information about the grass-web mailing list
