[GRASSweb-list] markus: web/announces announce_grass622.html, 1.9, 1.10
grass at intevation.de grass at intevation.de
Sun Jul 15 11:18:21 EDT 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv6214
Modified Files:
Log Message:
more backports; ready for release
Index: announce_grass622.html
RCS file: /grassrepository/web/announces/announce_grass622.html,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- announce_grass622.html	3 Jul 2007 03:17:45 -0000	1.9
+++ announce_grass622.html	15 Jul 2007 15:18:19 -0000	1.10
@@ -165,6 +165,7 @@
  <li> <b>r.flow</b>: 3D length fix; 64bit segfault fix
  <li> <b>r.in.bin</b>: Honour the -s flag for 2-byte and 4-byte data
  <li> <b>r.in.wms</b>: Fix a number of teething problems; remove bashisms
+ <li> <b>r.median</b>: fix broken internal r.stats call
  <li> <b>r.profile</b>: Allow data from stdin, exit with error if coordinate
       request is outside the current region settings (was reporting bogus data)
  <li> <b>r.proj</b> bilinear: Fix inverted interpolation expression
@@ -174,9 +175,11 @@
  <li> <b>v.build.polylines</b>: Build polylines out of a closed boundaries,
          remove doubled vertices at each node
  <li> <b>v.clean</b> snap tool: Remove doubled vertices
+ <li> <b>v.db.addtable</b>: fixed error treatment when wrong SQL types were defined
  <li> <b>v.dissolve</b>: Dissolve common boundaries by attribute;
       fix for DBMI error if input map is specified with @mapset
  <li> <b>v.in.ascii</b>: Skip over blank lines without error, improve robustness
+ <li> <b>v.in.gns</b>: fixed format incompatibility with current GNS format
  <li> <b>v.in.gpsbabel</b>: Attribute and point import fixed for tracks and routes; works with Mac OSX
  <li> <b>v.in.region</b>: Add additional vertex if necessary to ensure line
       segments don't exceed 180 degrees longitude and wrap the wrong way around the world
More information about the grass-web mailing list
