[GRASSweb-list] markus: web/grass62/binary/mswindows README.html, 1.14, 1.15 setup.ini, 1.2, 1.3
grass at intevation.de grass at intevation.de
Wed Jul 18 09:50:08 EDT 2007
Author: markus
Update of /grassrepository/web/grass62/binary/mswindows
In directory doto:/tmp/cvs-serv25999
Modified Files:
	README.html setup.ini
Log Message:
new 6.2.2 thanks to glynn
Index: README.html
RCS file: /grassrepository/web/grass62/binary/mswindows/README.html,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -d -r1.14 -r1.15
--- README.html	3 May 2007 03:33:06 -0000	1.14
+++ README.html	18 Jul 2007 13:50:05 -0000	1.15
@@ -37,7 +37,7 @@
 (or a <a href="http://grass.ibiblio.org/mirrors.php">local mirror</a>)
 instead of <tt>http://geni.ath.cx/grass</tt>.
-Also, in step #5 the version is 6.2.1-1 instead of 6.0.cvs-1, and there's no
+Also, in step #5 the version is 6.2.2-1 instead of 6.0.cvs-1, and there's no
 grass.bat script.
 <h5>Required packages:</h5>
@@ -169,7 +169,7 @@
 From outside of GRASS you can run <tt>cygcheck</tt> to check for missing
 DLL libraries by first changing to GRASS's library directory:
 <pre>
-  cd /usr/local/grass-6.2.1/lib
+  cd /usr/local/grass-6.2.2/lib
   cygcheck ../bin/g.region
 </pre>
@@ -191,11 +191,11 @@
 <DD>
 <pre>
 $ cd /
-$ tar xjf /path/to/grass-6.2.1-1.cygwin.tar.bz2
+$ tar xjf /path/to/grass-6.2.2-1.cygwin.tar.bz2
 </pre>
 </DD>
-Everything will be /usr/local/grass-6.2.1, except for the grass62
+Everything will be /usr/local/grass-6.2.2, except for the grass62
 script which is in /usr/local/bin.
 <p>
 Regarding external dependencies: the only dependencies which aren't
Index: setup.ini
RCS file: /grassrepository/web/grass62/binary/mswindows/setup.ini,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- setup.ini	21 Feb 2007 07:20:14 -0000	1.2
+++ setup.ini	18 Jul 2007 13:50:05 -0000	1.3
@@ -1,14 +1,21 @@
 @ grass
 sdesc: "GRASS - Geographic Resources Analysis Support System"
 category: Database
-requires: gdal tcltk-grass cygwin xorg-x11-bin xorg-x11-base xterm libjpeg62 libtiff5 libpng12 libncurses8 fftw3 lesstif proj sunrpc freetype2 readline postgresql
+requires: cygwin gdal libintl8 libiconv2 freetype2 libpng12 fftw3 libncurses8 proj readline libtiff5 xterm xorg-x11-base lesstif
 version: 6.2.1-1
 install: grass-6.2.1-1.cygwin.tar.bz2 17279341 910600206b7a92871d9cdf9a46dc54ab
+@ grass
+sdesc: "GRASS - Geographic Resources Analysis Support System"
+category: Database
+version: 6.2.2-1
+install: grass-6.2.2-1.cygwin.tar.bz2 16313625 5506d382b1e1b010b66677cb99991bb8
 @ gdal
 sdesc: "GDAL - Geospatial Data Abstraction Library"
 category: Graphics Libs
-requires: jasper openssl
+requires: cygwin jasper libpng12 libpq4 libtiff5
 version: 1.3.1-1
 install: gdal-1.3.1-1.cygwin.tar.bz2 3431834 662ed588d2a155e620d165b85a6284da
More information about the grass-web mailing list
