[GRASSweb-list] markus: web/devel devel.inc,1.40,1.41
grass at intevation.de grass at intevation.de
Sun Mar 4 02:44:59 EST 2007
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv29954
Modified Files:
	devel.inc
Log Message:
links updated
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.40
retrieving revision 1.41
diff -u -d -r1.40 -r1.41
--- devel.inc	25 Nov 2006 12:33:46 -0000	1.40
+++ devel.inc	4 Mar 2007 07:44:57 -0000	1.41
@@ -96,9 +96,9 @@
 also offer <a href="../download/index.php">precompiled binaries</a>).
 <br>
 The <b>configuration</b> requires a set of installed libraries which are
-described in the file <a href="../grass61/source/REQUIREMENTS.html">REQUIREMENTS.html</a>
+described in the file <a href="../grass63/source/REQUIREMENTS.html">REQUIREMENTS.html</a>
 file (which you also find in the main directory of the source code tarball).
-The <b>compilation</b> is desribed in the <a href="../grass61/source/INSTALL">INSTALL</a>
+The <b>compilation</b> is desribed in the <a href="../grass63/source/INSTALL">INSTALL</a>
 Dear Newbie, please be so kind to search the
 <a href="../searchgrass.php">developers mailing list archive</a> before asking
@@ -156,18 +156,19 @@
 (which you find in the GRASS source code).
 <ul>
+<li> Legal aspects of code contributions (RFC2): these <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/rfc/RFC2_PSC.dox?rev=HEAD&content-type=text/vnd.viewcvs-markup">rules</a> have to be accepted to gain CVS write access
 <li> C language coding standards: Check your code against the rules defined in the
      'SUBMITTING' file (find it in the main directory of the GRASS source
-     code and also <a href=../grass61/source/SUBMITTING>SUBMITTING</a>). This ensures
+     code and also <a href=../grass63/source/SUBMITTING>SUBMITTING</a>). This ensures
      a smooth integration into the standard GRASS code base.
 <li> Shell script coding standards: Check your code against the rules defined in the
      'SUBMITTING_SCRIPTS' file (find it in the main directory of the GRASS source
-     code and also <a href=../grass61/source/SUBMITTING_SCRIPTS>SUBMITTING_SCRIPTS</a>). This ensures
+     code and also <a href=../grass63/source/SUBMITTING_SCRIPTS>SUBMITTING_SCRIPTS</a>). This ensures
      a smooth integration into the standard GRASS code base and avoids portability
      problems.
 <li> Tcl/Tk script coding standards: Check your code against the rules defined in the
      'SUBMITTING_TCLTK' file (find it in the main directory of the GRASS source
-     code and also <a href=../grass61/source/SUBMITTING_TCLTK>SUBMITTING_TCLTK</a>).
+     code and also <a href=../grass63/source/SUBMITTING_TCLTK>SUBMITTING_TCLTK</a>).
 <li> Code submission: Please contact a member of the
      <A HREF="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass6/AUTHORS">GRASS Development Team</a>
      or write to the development mailing list (see <A HREF="#list">above</a>).<br>
More information about the grass-web mailing list
