[GRASSweb-list] martinl: web/devel devel.inc,1.41,1.42
    grass at intevation.de
    Thu Mar  8 08:07:42 EST 2007
Author: martinl
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv9279
Modified Files:
	devel.inc
Log Message:
HTML version of GRASS5.x Programmer's Manual is not available
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.41
retrieving revision 1.42
diff -u -d -r1.41 -r1.42
--- devel.inc	4 Mar 2007 07:44:57 -0000	1.41
+++ devel.inc	8 Mar 2007 13:07:40 -0000	1.42
@@ -119,9 +119,10 @@
  System (GRASS), GNU General Public License. ITC-irst, Trento, Italy, http://grass.itc.it
 <ul>
-<li><b>GRASS 6.0/6.1:</b>
+<li><b>GRASS 6.0/6.1/6.2/6.3:</b>
-The manual has been integrated into the source code (doxygen format) and
+The manual has been integrated into the source code (<a
+href="http://www.stack.nl/~dimitri/doxygen/">doxygen</a> format) and
 can be extracted with 'make pdfdocs' or downloaded from the
 <a href="../download/index.php">download page</a>.
@@ -138,12 +139,16 @@
 <li><b>GRASS 5.0/5.3/5.4 (old!):</b>
  <ul>
   <li>GRASS 5.0/5.3 Programmer's Manual [ <a
-   href="../grass50/progmangrass50.pdf">PDF</a>, 2.3 MB |
-   <a href="http://mpa.itc.it/markus/grass50progman/">HTML</a> ]
+   href="../grass50/progmangrass50.pdf">PDF</a>, 2.3 MB ]
+	   <a href="http://mpa.itc.it/markus/grass50progman/">HTML</a>
  </ul>
 </ul>
 <P>
-Debugging: hints are collected in doc/debugging.txt in the source code package.
+Debugging: hints are collected in <a
+href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/debugging.txt?rev=HEAD&content-type=text/vnd.viewcvs-markup">doc/debugging.txt</a>
+in the source code package.
 <a name=submission></a>
 <h2>Code submission</h2>
More information about the grass-web
