[GRASSweb-list] markus: web/announces announce_grass630.html, 1.6, 1.7
grass at intevation.de grass at intevation.de
Thu Mar 15 06:54:06 EDT 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv18955
Modified Files:
Log Message:
v.support added
Index: announce_grass630.html
RCS file: /grassrepository/web/announces/announce_grass630.html,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- announce_grass630.html	28 Feb 2007 21:34:09 -0000	1.6
+++ announce_grass630.html	15 Mar 2007 10:54:04 -0000	1.7
@@ -221,9 +221,10 @@
  <li> <b>v.extract</b>: don't crash on DBMI failure
  <li> <b>v.in.db</b>: no longer copy the entire table if where= option is used
  <li> <b>v.in.ogr</b>: locale bug fixed; memory leak fixed
- <li> <b>v.lidar.*</b>: <font color=red>NEW</font> - new Lidar data analysis tools
+ <li> <b>v.lidar.*</b>: <font color=red>NEW</font> - Lidar data analysis tools
  <li> <b>v.out.svg</b>: <font color=red>NEW</font> - vector to SVG export
  <li> <b>v.proj</b>: leave z co-ordinates in 3-D vectors untouched by default
+ <li> <b>v.support</b>: <font color=red>NEW</font> - set/update vector map metadata in the header file
  <li> <b>v.surf.bspline</b>: <font color=red>NEW</font> - bspline interpolation
  <li> <b>v.surf.idw</b>: don't require topology to be built for input vector points file</ul>
 </ul>
More information about the grass-web mailing list
