[GRASSweb-list] hamish: web/grass62/binary/mswindows README.html, 1.11, 1.12
grass at intevation.de grass at intevation.de
Thu Mar 22 03:17:48 EDT 2007
Author: hamish
Update of /grassrepository/web/grass62/binary/mswindows
In directory doto:/tmp/cvs-serv8128
Modified Files:
	README.html
Log Message:
apparently I'm slightly dyslexic
Index: README.html
RCS file: /grassrepository/web/grass62/binary/mswindows/README.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- README.html	21 Feb 2007 07:20:14 -0000	1.11
+++ README.html	22 Mar 2007 07:17:46 -0000	1.12
@@ -74,7 +74,7 @@
 <a name="data"></a>
 <h4>Installing data:</h4>
-Create a new directory in your Cywgin home directory called
+Create a new directory in your Cygwin home directory called
 "<tt>grassdata/</tt>" for your data.<BR> For example, using the
 <a href="http://grass.ibiblio.org/download/data.php">Spearfish sample dataset</a>:
 <BR>(<i>assumes you have already downloaded the dataset and put the file in
@@ -153,7 +153,7 @@
 out which one run "<tt>cygcheck g.region</tt>" (replace g.region with the
 offending module's name). You can then search for the name of the package
 that contains the missing file at the <a href="http://cygwin.com/packages/">
-Cygwin package search page</a>. Re-run the Cywgin installer to load the
+Cygwin package search page</a>. Re-run the Cygwin installer to load the
 missing package; it will have remembered your earlier selections.
 Feel free to file a bug report as well (<a href="#bugs">see below</a>).
 <P>
@@ -178,7 +178,7 @@
 <h4>Installing packages by hand:</h4>
 (<i>only required if you didn't install via a GRASS mirror (with "setup.ini")
-from within the Cywin installer</i>)
+from within the Cygwin installer</i>)
 <P>
 The winGRASS package is just a .tar.bz2 file. It can be extracted into Cygwin's
More information about the grass-web mailing list
