[GRASSweb-list] markus: web/intro main.inc,1.12,1.13
grass at intevation.de grass at intevation.de
Fri Mar 23 11:57:01 EDT 2007
Author: markus
Update of /grassrepository/web/intro
In directory doto:/tmp/cvs-serv22802/intro
Modified Files:
	main.inc
Log Message:
changed relevant active pages to FBK-irst (formerly ITC-irst)
Index: main.inc
RCS file: /grassrepository/web/intro/main.inc,v
retrieving revision 1.12
retrieving revision 1.13
diff -u -d -r1.12 -r1.13
--- main.inc	2 May 2006 17:01:56 -0000	1.12
+++ main.inc	23 Mar 2007 15:56:59 -0000	1.13
@@ -33,7 +33,7 @@
 <li>ASU, USA: In the <a href="http://www.asu.edu/clas/anthropology/research/LLSMB/">Mediterranean
     Landscape Dynamics/NFS</a> project GRASS is used.</li>
 <li>Duke University, USA: GRASS is used for <a href="http://terrain.cs.duke.edu/">LIDAR and large scale terrain analysis</a>.</li>
-<li>ITC-irst, Italy: GRASS is used for
+<li>FBK-irst (formerly ITC-irst), Italy: GRASS is used for
     <a href="http://mpa.itc.it/pr-ux-ri-en.html">detection of unexploded bombs from World War II</a> as
     well as <a href="http://mpa.itc.it/pr-wi-ri.html">Road-kill risk maps</a> and other projects.</li>
 <li>European Commission, DG - Joint Research Centre, Italy:
More information about the grass-web mailing list
