[GRASSweb-list] markus: web/announces announce_grass622.html, 1.1,
1.2
grass at intevation.de
Tue May 29 15:22:50 EDT 2007
- Previous message: [GRASSweb-list] markus: web newsarchive.html, 1.54, 1.55 rss.xml,
1.18, 1.19
- Next message: [GRASSweb-list] markus: web/devel cvstags.inc, 1.22,
1.23 grasshist.html, 1.28, 1.29 grassreleases.html, 1.24, 1.25
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv10593/announces
Modified Files:
Log Message:
GRASS 6.2.2RC1 released
Index: announce_grass622.html
RCS file: /grassrepository/web/announces/announce_grass622.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- announce_grass622.html 11 Apr 2007 13:00:16 -0000 1.1
+++ announce_grass622.html 29 May 2007 19:22:48 -0000 1.2
@@ -110,27 +110,52 @@
<li> System and Libraries:
<ul>
- <li> DBMI/SQL parser: added missing TIME support
- <li> enable geodetic datum for Krovak
- <li> Slovakia Datum (hermannskogel) fixed
+ <li> <b>DBMI/SQL parser</b>: added missing TIME support
+ <li> <b>DBF Driver</b>: add missing SQL TIME support
+ <li> <b>sqlite driver</b>: 'date' support
+ <li> <b>QGIS-GRASS DB bug</b>: fixed https://svn.qgis.org/trac/ticket/448
+ <li> <b>geodetic datum</b>:enable geodetic datum for Krovak, Slovakia Datum (hermannskogel) fixed
+</ul>
+<li> Graphical User Interface:
+<ul>
+ <li> <b>gis.m</b>: Backport various GIS.m GUI enhancements. Clickable GUI buttons; More robust error handling; Main window cosmetics; Fix lwidth bug; Typos
+ <li> <b>GUI menu</b>: remove non-functional font setting entries
+ <li> <b>GUI startup</b>: backport Michael's new EPSG code search tool
</ul>
<li> Modules/Scripts:
<ul>
+ <li> <b>d.labels</b>: backport rotation fixes
<li> <b>d.vect</b>: display also nodes in topo mode
+ <li> <b>d.vect.thematic</b>: remove Bashisms
+ <li> <b>v.clean</b> tool=snap: doubled vertices in the output
<li> <b>g.mremove</b>: work also in gis.m
- <li> <b>ps.map</b>: correct scaling when units are not meters. (bugs # 3096 and 5454)
- <li> <b>r.contour</b>: fixing segfault
+ <li> <b>lib/gis</b>: backport false easting/northing test
+ <li> <b>ps.map</b>: Fix landscape mode. Fix map scaling when map projection is not measured in meters
+ <li> <b>r.contour</b>: fix segfault
+ <li> <b>r.distance</b>: null distance for area in area
<li> <b>r.flow</b>: 3d length fix; 64bit segfault fix
<li> <b>r.in.bin</b>: honour -s flag for 2-byte and 4-byte data
- <li> <b>r.profile</b>: die if coordinate request outsite current region settings, was reporting bogus data
- <li> <b>r.proj</b>: fix bilinear interpolation expression (row/column were swapped)
- <li> <b>r.reclass.area</b>: don't leave clump file behind
- <li> <b>r.reclass.area</b>: label support added
- <li> <b>scripts</b>: various fixes backported
+ <li> <b>r.profile</b>: Allow data from stdin, Die if coordinate request outsite current region settings, was reporting bogus data
+ <li> <b>r.proj</b> bilinear: Fix interpolation expression
+ <li> <b>r.reclass.area</b>: don't leave clump file behind, label support added
+ <li> <b>v.build.polylines</b>: fails to build a polyline out of a closed boundary, vertices are doubled at each node
+ <li> <b>r.tileset</b>: Fix break due to platform specific units parsing; Requires Bash
+ <li> <b>scripts/</b>: various fixes backported, remove all bashisms from Bourne scripts
+ <li> <b>Slovakia Hermannskogel datum fixed again
+ <li> <b>v.build.polylines</b>: two bugs: #4247 #4249
+ <li> <b>v.dissolve</b>: dissolve common boundaries by attribute
+ <li> <b>v.in.ascii</b>: skip blank lines,
+ <li> <b>v.in.gpsbabel</b>: attribute import fixed for tracks and routes
<li> <b>v.in.region</b>: add additional vertex if necessary to ensure line segments don't exceed 180 degrees longitude
+ <li> <b>v.lidar.*</b>: various fixes backported
<li> <b>v.report</b>: backported fixes for RT bug #4459 and [grass-code I][#301]
+ <li> <b>v.segment</b>: Make side_offset functional
<li> <b>v.to.db</b>: fix compactness formula parentheses to match actual formula
+ <li> <b>v.type</b>: Wrap it so it works from the GUI menus
+ <li> <b>v.what</b>: fix for multiple input coords
</ul>
</ul>
@@ -178,7 +203,7 @@
<li> GRASS GIS 6.2.0 released 31 October 2006
<li> GRASS GIS 6.2.1RC1 released 6 December 2006
<li> GRASS GIS 6.2.1 released 12 December 2006
-<li> GRASS GIS 6.2.2RC1 released 11 April 2007
+<li> GRASS GIS 6.2.2RC1 released 29 May 2007
</ul>
<hr>
1.18, 1.19
[ date ]
[ thread ]
[ subject ]
[ author ]
More information about the grass-web
