[GRASSweb-list] markus: web/announces announce_grass622.html, 1.2,
1.3
grass at intevation.de
Tue May 29 15:29:52 EDT 2007
Author: markus
Update of /grassrepository/web/announces
In directory doto:/tmp/cvs-serv10767
Modified Files:
Log Message:
fix
Index: announce_grass622.html
RCS file: /grassrepository/web/announces/announce_grass622.html,v
retrieving revision 1.2
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- announce_grass622.html 29 May 2007 19:22:48 -0000 1.2
+++ announce_grass622.html 29 May 2007 19:29:50 -0000 1.3
@@ -144,7 +144,6 @@
<li> <b>v.build.polylines</b>: fails to build a polyline out of a closed boundary, vertices are doubled at each node
<li> <b>r.tileset</b>: Fix break due to platform specific units parsing; Requires Bash
<li> <b>scripts/</b>: various fixes backported, remove all bashisms from Bourne scripts
- <li> <b>Slovakia Hermannskogel datum fixed again
<li> <b>v.build.polylines</b>: two bugs: #4247 #4249
<li> <b>v.dissolve</b>: dissolve common boundaries by attribute
<li> <b>v.in.ascii</b>: skip blank lines,
More information about the grass-web
