[GRASSweb-list] markus: web/grass62/binary/mswindows setup.ini, 1.4, 1.5
grass at intevation.de grass at intevation.de
Fri Sep 7 00:47:25 EDT 2007
Author: markus
Update of /grassrepository/web/grass62/binary/mswindows
In directory doto:/tmp/cvs-serv7733
Modified Files:
	setup.ini
Log Message:
fix here, not on server
Index: setup.ini
RCS file: /grassrepository/web/grass62/binary/mswindows/setup.ini,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- setup.ini	29 Aug 2007 08:59:58 -0000	1.4
+++ setup.ini	7 Sep 2007 04:47:23 -0000	1.5
@@ -1,16 +1,9 @@
 @ grass
 sdesc: "GRASS - Geographic Resources Analysis Support System"
 category: Database
-requires: cygwin gdal libintl8 libiconv2 freetype2 libpng12 fftw3 libncurses8 proj readline libtiff5 xterm xorg-x11-base lesstif
-version: 6.2.1-1
-install: grass-6.2.1-1.cygwin.tar.bz2 17279341 910600206b7a92871d9cdf9a46dc54ab
-@ grass
-sdesc: "GRASS - Geographic Resources Analysis Support System"
-category: Database
 requires: cygwin gdal libintl8 libiconv2 freetype2 libpng12 fftw3 libncurses8 proj readline libtiff5 xterm xorg-x11-base lesstif tcltk-grass
-version: 6.2.2-1
-install: grass-6.2.2-1.cygwin.tar.bz2 16313625 5506d382b1e1b010b66677cb99991bb8
+version: 6.2.2-2
+install: grass-6.2.2-2.cygwin.tar.bz2 16558552 54a26ee45cb43445a776c8bdface42c8
 @ gdal
 sdesc: "GDAL - Geospatial Data Abstraction Library"
More information about the grass-web mailing list
