[GRASSweb-list] markus: web/devel devel.inc,1.45,1.46
grass at intevation.de
Mon Sep 17 04:29:33 EDT 2007
Author: markus
Update of /grassrepository/web/devel
In directory doto:/tmp/cvs-serv14794
Modified Files:
devel.inc
Log Message:
cosmetics
Index: devel.inc
RCS file: /grassrepository/web/devel/devel.inc,v
retrieving revision 1.45
retrieving revision 1.46
diff -u -d -r1.45 -r1.46
--- devel.inc 14 May 2007 19:16:28 -0000 1.45
+++ devel.inc 17 Sep 2007 08:29:31 -0000 1.46
@@ -129,8 +129,8 @@
<ul>
<li>GRASS <a href=../grass63/manuals/>6 Programmer's Manual</a>
(PDF and packaged HTM; complete, updated weekly every Saturday)
- <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/">6 Programmer's Manual</a> (HTML, updated regularly, generated with 'make htmldocs-single')
- <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/swig/">SWIG interface</a> (HTML, updated regularly)
+ <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/">6 Programmer's Manual</a> (HTML, weekly updated; generate locally with 'make htmldocs-single' from source code)
+ <li> GRASS <a href="http://mpa.itc.it/markus/grass63progman/swig/">SWIG interface</a> (HTML, weekly updated)
<li> <a href="../searchgrass.php">Search GRASS 6 Programmer's Manual</a>
<li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/raster/">r.example</a>: example C code for GRASS raster programming
<li> <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass6/doc/vector/v.example/">v.example</a>: example C code for GRASS 6 vector programming
More information about the grass-web
