[GRASSweb-list] hamish: web/screenshots raster.inc,1.1,1.2
grass at intevation.de
Sun Sep 23 08:16:59 EDT 2007
Author: hamish
Update of /grassrepository/web/screenshots
In directory doto:/tmp/cvs-serv13872
Modified Files:
raster.inc
Log Message:
increase spacing between images, border around clickables
Index: raster.inc
RCS file: /grassrepository/web/screenshots/raster.inc,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- raster.inc 23 Sep 2007 06:58:23 -0000 1.1
+++ raster.inc 23 Sep 2007 12:16:57 -0000 1.2
@@ -26,19 +26,19 @@
<p><a href="../grass61/screenshots/images/srtm_trento_voidfill.png" target="_blank"><img src="../grass61/screenshots/images/srtm_trento_voidfill_small.jpg" border="1"></a></p>
<p>Void filling in SRTM DEM data with splines (r.fillnulls). See related article
in <a href="../newsletter/index.php">GRASS Newsletter #3, June 2005</a>
- (screenshot: M. Neteler)<br>
+ (screenshot: M. Neteler)<br><br>
<p><a href="../grass61/screenshots/images/global_rad_noshadow_trento_srtmV2.jpg" target="_blank"><img src="../grass61/screenshots/images/global_rad_noshadow_trento_srtmV2_small.jpg" border="1"></a></p>
<p>Accumulated daily global radiation for 1 year at Trento (Italy) without shadow and
cloud correction (r.sun). The valleys are at 200-600m elevation while the mountains reach 2100m.
- (SRTM V2 data, screenshot: M. Neteler)<br>
+ (SRTM V2 data, screenshot: M. Neteler)<br><br>
<p><a href="../grass61/screenshots/images/global_shadow_rad_shadow_corrected_trento_srtmV2.jpg" target="_blank"><img src="../grass61/screenshots/images/global_shadow_rad_shadow_corrected_trento_srtmV2_small.jpg" border="1"></a></p>
<p>Accumulated daily global radiation for 1 year at Trento (Italy) with shadow correction (r.sun).
The valleys are at 200-600m elevation while the mountains reach 2100m. This map is
much closer to reality, optional cloud correction was not applied. The color table is identical
to above uncorrected map.
<p><a href="../grass61/screenshots/images/srtmV2_trento.jpg" target="_blank"><img src="../grass61/screenshots/images/srtmV2_trento_small.jpg" border="1"></a></p>
<p>Visualization of SRTM V2 DEM used for above global radiation analysis (SRTM V2 data, screenshot: M. Neteler)<br>
@@ -55,11 +55,11 @@
<td>
<div align="center">
- <p><a href="../grass60/screenshots/images/etopo2_grass_laea_9_48N_0E.jpg" target="_blank"><img src="../grass60/screenshots/images/etopo2_grass_laea_9_48N_0E_small.jpg" alt="Lambert Equal Area projection of ETOPO2" border="0"></a></p>
+ <p><a href="../grass60/screenshots/images/etopo2_grass_laea_9_48N_0E.jpg" target="_blank"><img src="../grass60/screenshots/images/etopo2_grass_laea_9_48N_0E_small.jpg" alt="Lambert Equal Area projection of ETOPO2" border="1"></a></p>
<p>Lambert Equal Area projection of ETOPO2.
- <p><a href="../grass60/screenshots/images/distance2water.jpg" target="_blank"><img src="../grass60/screenshots/images/distance2water_small.jpg" alt="Distance to water" border="0"></a></p>
+ <p><a href="../grass60/screenshots/images/distance2water.jpg" target="_blank"><img src="../grass60/screenshots/images/distance2water_small.jpg" alt="Distance to water" border="1"></a></p>
<p>Distance to water
More information about the grass-web
