[GRASSweb-list] hamish: web/screenshots platforms.php,1.1,1.2
grass at intevation.de grass at intevation.de
Mon Sep 24 11:40:52 EDT 2007
Author: hamish
Update of /grassrepository/web/screenshots
In directory doto:/tmp/cvs-serv19264
Modified Files:
	platforms.php
Log Message:
de-headline blurb
Index: platforms.php
RCS file: /grassrepository/web/screenshots/platforms.php,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- platforms.php	24 Sep 2007 12:06:09 -0000	1.1
+++ platforms.php	24 Sep 2007 15:40:50 -0000	1.2
@@ -74,23 +74,22 @@
         <!-- MAIN PART -->
 	<h3>Screenshots of GRASS GIS in action</h3>
-	<h4>The GRASS source code is written in portable ANSI-C and is fully POSIX compliant.
-	    It runs on most known flavors of UNIX including Linux and Mac OSX,
-	    as well as MS Windows with Cygwin. Development is well underway on a
-	    native MS Windows port, and an experimental version is available for download now.
-	    Cross platform GUI toolkits are used to ensure a consistent user experience
-	    regardless of the hardware. The old GUI used Tcl/Tk, the new GUI is using WxPython.
-	    GRASS has been run on everything from supercomputers to handheld PDAs. It is
-	    well adapted for life on a single-user workstation, a large multi-user system,
-	    or application server and thin clients with mapset-level access control.
-	</h4>
+	The GRASS source code is written in portable ANSI-C and is fully POSIX compliant.
+	It runs on most known flavors of UNIX including Linux and Mac OSX,
+	as well as MS Windows with Cygwin. Development is well underway on a
+	native MS Windows port, with an experimental version available for download now.
+	GRASS has been run on everything from supercomputers to handheld PDAs. It is
+	well adapted for life on a single-user workstation, a large multi-user system,
+	or application server and thin clients, with mapset-level access control.
+	Cross platform GUI toolkits are used to ensure a consistent user experience
+	regardless of the hardware. The old GUI used Tcl/Tk, the new GUI is using WxPython.
         <?php
          include("platforms.inc");
         <P>
-        <i>Please also select from the left menu.</i>
+        <i>Please also select from the menu on the left.</i>
 <p>
 <table align="center" border="1">
More information about the grass-web mailing list
