[GRASSweb-list] hamish: web/screenshots vector_60.inc, NONE,
1.1 vector_61.inc, NONE, 1.1 vector_63.inc, NONE,
1.1 vector.php, 1.3, 1.4 raster.inc, 1.5, 1.6
grass at intevation.de
Tue Sep 25 03:25:33 EDT 2007
Author: hamish
Update of /grassrepository/web/screenshots
In directory doto:/tmp/cvs-serv9744
Modified Files:
vector.php raster.inc
Added Files:
vector_60.inc vector_61.inc vector_63.inc
Log Message:
split vect shots into per version files; fix intro URLs
--- NEW FILE: vector_60.inc ---
<h4>GRASS 6.0</h4>
<center>
<table width="60%" border="0">
<tr valign="baseline">
<td>
<div align="center">
<p><a href="../grass60/screenshots/images/v.digit.jpg" target="_blank"><img src="../grass60/screenshots/images/v.digit_small.jpg" width="311" height="160" border="1"></a></p>
<p>Heads up digitizing with v.digit</p>
</div></td>
<td>
<p><a href="../grass60/screenshots/images/v.buffer.png" target="_blank"><img src="../grass60/screenshots/images/v.buffer-small.png" width="222" height="200" border="1"></a></p>
<p align="center">Buffering with v.buffer</p>
</div></td>
</tr>
</table>
<td colspan="3" valign="bottom">
<P> </p>
<h5>Overlapping polygons</h5>
</div></td>
</tr>
<td valign="bottom">
<p><a href="../grass60/screenshots/images/fire1.png" target="_blank"><img src="../grass60/screenshots/images/fire1-small.png" width="198" height="200" border="1"></a> </p>
<p>Overlapping polygons input from Shapefile (or any other OGR simple feature format)</p>
</div></td>
<p><a href="../grass60/screenshots/images/fire2.png" target="_blank"><img src="../grass60/screenshots/images/fire2-small.png" width="198" height="200" border="1"></a></p>
<p>Result (areas colored by number of overlapping areas, categories of layer 1 and 2)</p>
</div></td>
</tr>
<td colspan="2" valign="bottom">
<p><em>Example of import and use in GRASS</em></p>
<div class="code"><pre>
v.in.ogr dsn=./shp/ layer=fire output=fire_p
v.category input=fire_p output=fire_c type=centroid field=2
echo "create table fire_c_2 (id int, num int)" | db.execute
v.db.connect map=fire_c driver=pg database=bridge layer=2 table=fire_c_2 key=id
v.to.db map=fire_c layer=2 option=cat col1=id
v.to.db map=fire_c layer=2 qlayer=1 option=query col1=num qcol="count(*)" type=centroid</pre></div>
<p>Number of overlapping features is also written as category to centroid.</p>
<p> </p>
</td>
</tr>
<p><a href="../grass60/screenshots/images/bridge.png" target="_blank"><img src="../grass60/screenshots/images/bridge-small.png" width="200" height="130" border="1"></a></p>
<p>Another example of overlapping features in one layer (overpass)</p>
</div></td>
</tr>
</table>
<table width="55%" border="0">
<P> </p>
<h5>Vector overlay using v.overlay</h5>
</div></td>
</tr>
<tr>
<td colspan="2"><div align="left">
<p align="center"><a href="../grass60/screenshots/images/v.overlay_a.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_a-small.png" width="207" height="200" border="1"></a>
<a href="../grass60/screenshots/images/v.overlay_b.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_b-small.png" width="207" height="200" border="1"></a></p>
<p align="center">Input A and B</p>
</div>
</td>
</tr>
<tr valign="bottom">
<td>
<p><a href="../grass60/screenshots/images/v.overlay_and.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_and-small.png" width="207" height="200" border="1"></a></p>
<p>intersection (operator=and)<br>
</div></td>
<td>
<p><a href="../grass60/screenshots/images/v.overlay_or.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_or-small.png" width="207" height="200" border="1"></a></p>
<p>union (operator=or)</p>
</div></td>
</tr>
<td>
<p> </p>
<p><a href="../grass60/screenshots/images/v.overlay_not.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_not-small.png" width="207" height="200" border="1"></a></p>
<p>not (operator=not)</p>
</div>
<td>
<p><a href="../grass60/screenshots/images/v.overlay_xor.png" target="_blank"><img src="../grass60/screenshots/images/v.overlay_xor-small.png" width="207" height="200" border="1"></a></p>
<p>exclusive or (operator=xor)</p>
</div>
</td>
</tr>
</table>
<table width="50%" border="0">
<P> </p>
<h5>Charting using d.vect.chart</h5>
</div></td>
</tr>
<td>
<p><a href="../grass60/screenshots/images/d.vect.chart_pie.png" target="_blank"><img src="../grass60/screenshots/images/d.vect.chart_pie-small.png" alt="Pie chart" width="200" height="166" border="1"></a></p>
<p align="center">Pie charts (default)</p>
</div>
</td>
<td>
<p><a href="../grass60/screenshots/images/d.vect.chart_bar.png" target="_blank"><img src="../grass60/screenshots/images/d.vect.chart_bar-small.png" alt="Bar chart" width="200" height="166" border="1"></a></p>
<p>Bar charts (ctype=bar)<br>
</div>
</td>
</tr>
</table>
<table width="80%" border="0" cellspacing="5">
<P> </p>
<h5>Network analysis</h5>
</div></td>
</tr>
<td>
<p><a href="../grass60/screenshots/images/d.path.jpg" target="_blank"><img src="../grass60/screenshots/images/d.path-small.jpg" alt="d.path" width="225" height="200" border="1"></a></p>
<p>Shortest path using d.path</p>
</div>
</td>
<td>
<p><a href="../grass60/screenshots/images/v.net.iso.png" target="_blank"><img src="../grass60/screenshots/images/v.net.iso-small.png" alt="v.net.iso" width="179" height="200" border="1"></a></p>
<p> Split network into bands using v.net.iso</p>
</div>
</td>
<td>
<p><a href="../grass60/screenshots/images/v.net.alloc.png" target="_blank"><img src="../grass60/screenshots/images/v.net.alloc-small.png" alt="v.net.alloc" width="228" height="200" border="1"></a></p>
<p>Allocate subnets using v.net.alloc</p>
</div>
</td>
</tr>
</table>
</center>
--- NEW FILE: vector_61.inc ---
<h4>GRASS 6.1</h4>
<table width="100%" border="0">
<td>
<p><a href="../grass61/screenshots/images/object_nviz_from_dxf_mesh.jpg" target="_blank"><img src="../grass61/screenshots/images/object_nviz_from_dxf_mesh_small.jpg" border="1"></a></p>
<p>3D DXF Mesh object, created in Blender and imported into GRASS
(screenshot: A. Bezzi, M. Neteler)<br>
<p><a href="../grass61/screenshots/images/trento3d.jpg" target="_blank"><img src="../grass61/screenshots/images/trento3d_small.jpg" border="1"></a></p>
<p>GRASS: building footprints extruded to 3D blocks (screenshot: M. Neteler)<br>
(data courtesy <a href="http://webapps.comune.trento.it/ambiente/">City of Trento</a>,
Italy - see "Mostra Strumenti Dati" for geodata download)</p>
<p><a href="../grass61/screenshots/images/trento3d_colors.jpg" target="_blank"><img src="../grass61/screenshots/images/trento3d_colors_small.jpg" border="1"></a></p>
<p>GRASS: building footprints extruded to 3D blocks, colored by building type (screenshot: M. Neteler)<br>
<p><a href="../grass61/screenshots/images/network_directions.png" target="_blank"><img src="../grass61/screenshots/images/network_directions_small.jpg" border="1"></a></p>
<p>Directions in vector networks (d.vect; screenshot: M. Neteler)</p>
<p><a href="../grass61/screenshots/images/network_one_way.png" target="_blank"><img src="../grass61/screenshots/images/network_one_way_small.jpg" border="1"></a></p>
<p>One way streets defined using backward/forward column attributes (drawn with ps.map; screenshot: M. Neteler)</p>
<p><a href="../grass61/screenshots/images/network_shortest_path_oneway.png" target="_blank"><img src="../grass61/screenshots/images/network_shortest_path_oneway_small.jpg" border="1"></a></p>
<p>Shortest path routing respecting one way streets (d.path; screenshot: M. Neteler)</p>
</div>
</td>
</tr>
</table>
--- NEW FILE: vector_63.inc ---
<h4>GRASS 6.3</h4>
<td>
<p><a href="../grass63/screenshots/images/grass6_moebius.png" target="_blank"><img src="../grass63/screenshots/images/grass6_moebius_small.jpg" border="1"></a></p>
<p>Möbius strip visualization to show the 3D vector capabilities of GRASS 6 - imported from 3D DXF (screenshot: M. Neteler)<br>
</div>
</td>
</tr>
</table>
Index: vector.php
RCS file: /grassrepository/web/screenshots/vector.php,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- vector.php 24 Sep 2007 11:21:45 -0000 1.3
+++ vector.php 25 Sep 2007 07:25:31 -0000 1.4
@@ -36,7 +36,7 @@
<td nowrap="nowrap">
<?php
include("title.inc");
</td>
</tr>
</tbody>
@@ -74,9 +74,24 @@
<!-- MAIN PART -->
<h3>Screenshots of GRASS in action</h3>
<h3>Vector support in GRASS GIS</h3>
- <?php
- include("vector.inc");
+ The GRASS Development Team and members of the user community have collected
+ numerous screenshots on these pages. Click image to see larger version.
+ <p>
+ For details, see the <a href="../grass63/manuals/html63_user/vectorintro.html">Vector map processing and network analysis</a> guide.
+ <P>
+ <?php
+ include("vector_63.inc");
+ <?php
+ include("vector_61.inc");
+ <?php
+ include("vector_60.inc");
<P>
<i>Please also select from the left menu.</i>
Index: raster.inc
RCS file: /grassrepository/web/screenshots/raster.inc,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- raster.inc 24 Sep 2007 12:25:28 -0000 1.5
+++ raster.inc 25 Sep 2007 07:25:31 -0000 1.6
@@ -2,8 +2,8 @@
<p>
-<a href="../../grass63/manuals/html63_user/rasterintro.html">Raster map</a> and
-<a href="../../grass63/manuals/html63_user/raster3dintro.html">3D raster data (voxel)</a>
+<a href="../grass63/manuals/html63_user/rasterintro.html">raster map</a> and
+<a href="../grass63/manuals/html63_user/raster3dintro.html">3D raster data (voxel)</a>
processing guides.
<P>
More information about the grass-web
