[GRASSweb-list] hamish: web/screenshots vector_60.inc,1.1,1.2
grass at intevation.de
Tue Sep 25 04:27:43 EDT 2007
Author: hamish
Update of /grassrepository/web/screenshots
In directory doto:/tmp/cvs-serv12246
Modified Files:
vector_60.inc
Log Message:
table spacing
Index: vector_60.inc
RCS file: /grassrepository/web/screenshots/vector_60.inc,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- vector_60.inc 25 Sep 2007 07:25:31 -0000 1.1
+++ vector_60.inc 25 Sep 2007 08:27:41 -0000 1.2
@@ -18,9 +18,9 @@
</table>
-<table width="60%" border="0">
+<table width="50%" border="0" cellpadding="5">
<tr valign="baseline">
- <td colspan="3" valign="bottom">
+ <td colspan="2" valign="bottom">
<div align="center">
<P> </p>
<h5>Overlapping polygons</h5>
@@ -40,22 +40,23 @@
<p>Result (areas colored by number of overlapping areas, categories of layer 1 and 2)</p>
</div></td>
</tr>
+</table>
- <tr valign="baseline">
- <td colspan="2" valign="bottom">
- <p><em>Example of import and use in GRASS</em></p>
- <div class="code"><pre>
- v.in.ogr dsn=./shp/ layer=fire output=fire_p
- v.category input=fire_p output=fire_c type=centroid field=2
- echo "create table fire_c_2 (id int, num int)" | db.execute
- v.db.connect map=fire_c driver=pg database=bridge layer=2 table=fire_c_2 key=id
- v.to.db map=fire_c layer=2 option=cat col1=id
- v.to.db map=fire_c layer=2 qlayer=1 option=query col1=num qcol="count(*)" type=centroid</pre></div>
- <p>Number of overlapping features is also written as category to centroid.</p>
- <p> </p>
- </td>
- </tr>
+<p><em>Example of import and use in GRASS</em></p>
+<div class="code"><pre>
+ v.in.ogr dsn=./shp/ layer=fire output=fire_p
+ v.category input=fire_p output=fire_c type=centroid field=2
+ echo "create table fire_c_2 (id int, num int)" | db.execute
+ v.db.connect map=fire_c driver=pg database=bridge layer=2 table=fire_c_2 key=id
+ v.to.db map=fire_c layer=2 option=cat col1=id
+ v.to.db map=fire_c layer=2 qlayer=1 option=query col1=num qcol="count(*)" type=centroid</pre>
+</div>
+<p>Number of overlapping features is also written as category to centroid.</p>
+<p> </p>
+<table width="200" border="0">
More information about the grass-web
