[GRASS-web] Slovakia mirror
    Pavol Cvengros
    pavol.cvengros at primeinteractive.net
    Fri Apr  8 04:46:48 EDT 2011
Dear Markus,
in next few days I am changing server to new/better hardware. I would
like to check if rsync access for mirrors is on IP or DNS record.
To be sure I am sending new IP address: 195.95.205.51
Domain will stay as it is: www.grass.sk
Best regards,
Pavol
On 24. 3. 2009 16:43, Markus Neteler wrote:
> Hello Pavol,
> I have added your site to the list - will show up in circa 30min from now.
> Thanks for hosting GRASS,
> Markus
> On Tue, Mar 24, 2009 at 8:43 AM, Pavol Cvengros
> <pavol.cvengros at primeinteractive.net>  wrote:
>> Hello Markus,
>> I have changed my rsync to mirror from grass.osgeo.org.
>> Best regards,
>> Pavol
>> On 23. 3. 2009 21:51, Markus Neteler wrote:
>>> Hello Pavol,
>>> I see that http://grass.sk/index.php
>>> is lagging behind for 3 days... maybe you need to read from
>>> grass.osgeo.org?
>>> The rsync server responds well.
>>> Best regards,
>>> Markus
>>> On Sun, Mar 22, 2009 at 12:18 PM, Pavol Cvengros
>>>> Hello,
>>>> rsync server on my server is set. Only one repository available from sync
>>>> and that is grass. Maximum 20 parallel connections.
>>>> Please test it and if everything will be ok I would like to apply for
>>>> tier 1
>>>> mirror server.
>>>> Rsync server: grass.sk
>>>> Best regards,
>>>> Pavol
>>>> On 11. 3. 2009 9:22, Markus Neteler wrote:
>>>> Hello Pavol,
>>>> On Wed, Mar 11, 2009 at 7:48 AM, Pavol Cvengros
>>>> Hello,
>>>> I am running Slovakia mirror on my private server with courtesy of Prime
>>>> Interactive Ltd. for a long time on domain grass.sk
>>>> I found that you are looking for tier 1 mirrors. What is needed to become
>>>> one? Is the only one condition to run rsync server to provide mirroring
>>>> capabilities for tier 2 server?
>>>> that's right! Just "be open", say, permit others to rsync from you.
>>>> All this originates from the times that the master site was grass.itc.it
>>>> with
>>>> limited bandwiths. grass.osgeo.org is well connected (thanks to
>>>> telascience.org)
>>>> so that we reach 2.x TB (!) peaks per months.
>>>> However, mirrors don't harm and we prefer a semi-decentralized
>>>> infrastructure
>>>> in case the North Atlantic or Pacific network bones get cut. Still we'd
>>>> remain
>>>> online :)
>>>> If you have enough bandwidth you may enable others to rsync from you.
>>>> Then please ping us here to update the mirror list (next of your mails
>>>> will
>>>> go through directly).
>>>> Best regards,
>>>> Markus
More information about the grass-web
