[GRASS-web] Fwd: [ibiblio.org #48154] grass.ibiblio.org is down / permission error
Markus Neteler neteler at osgeo.org
Fri Apr 22 03:54:25 EDT 2011
Also index.php should become the main file,
http://mirrors.ibiblio.org/grass/download/
Name	Last Modified	Size	Type
Parent Directory/	 	-  	Directory
addons.inc	2010-Jul-16 18:18:27	0.9K	application/octet-stream
addons.php	2011-Mar-02 12:11:03	2.4K	application/octet-stream
cdrom.inc	2010-Jul-19 12:11:03	3.6K	application/octet-stream
cdrom.php	2011-Mar-02 12:11:03	2.4K	application/octet-stream
data.inc	2010-Jul-16 18:18:27	1.6K	application/octet-stream
--> it should show the index.php instead...
Markus
On Fri, Apr 22, 2011 at 9:52 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Also the redirect fails:
> http://grass.ibiblio.org/download/index.php
> 403 Forbidden
> You don't have permission to access /download/index.php on this server.
> On Fri, Apr 22, 2011 at 9:51 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> No strong opinion but the updating apparently fails...
>> Markus
>> On Thu, Apr 21, 2011 at 11:18 PM,  <smlists at mac.com> wrote:
>>> Opinions?
>>> (see below)
>>> Begin forwarded message:
>>> From: "Justin via RT" <help at rt.ibiblio.org>
>>> Date: 21 April, 2011 14:40:08 EDT
>>> To: smitch at spamcop.net
>>> Cc: chuck at ibiblio.org, cmpalmer at metalab.unc.edu, ebailey at ibiblio.org,
>>> elrahals at ibiblio.org, ethan_kromhout at unc.edu, john at ibiblio.org,
>>> johnwood at email.unc.edu, pjones at ibiblio.org, styonsk at ibiblio.org
>>> Subject: [ibiblio.org #48154] grass.ibiblio.org is down / permission error
>>> Reply-To: help at rt.ibiblio.org
>>> Hi Scott,
>>> Thanks for your patience on this: I have an update for you.
>>> I've moved the grass mirror to http://mirrors.ibiblio.org/grass/ - php
>>> is working.  I've configured the mirror to update daily at 5:30am.
>>> We'd like to set up a 301 redirect for grass.ibiblio.org that will
>>> expire in 3 or so months.  We've found that is enough time for search
>>> engines and the like to update to the new address.  Would this work for
>>> your project?
>>> Justin
More information about the grass-web mailing list
