[GRASS-web] Error bug d.rast
Markus Neteler neteler at osgeo.org
Sun Jan 19 15:11:32 PST 2014
(please keep the conversation on the list)
Consider to use the latest stable version:
http://grass.osgeo.org/download/software/ms-windows/
On Fri, Jan 10, 2014 at 8:21 PM, Carmine Massarelli
<c.massarelli at gmail.com> wrote:
> Yes.
> It was not possibile to see any map. The same was visibile in grass module
> via qgis.
> Il giorno 10/gen/2014 20:18, "Markus Neteler" <neteler at osgeo.org> ha
> scritto:
>> Do you use the graphical user interface and then the error comes up?
>> Regards
>> Markus Neteler
>> On Fri, Jan 10, 2014 at 8:13 PM, Carmine Massarelli
>> > Hello,
>> > i have used both windows 7 and 8.1.
>> > The error is d.rast map=.... failed.
>> > The problem could be linked to wxphyton.
>> > Best reguards
>> > Carmine Massarelli PhD
>> > Il giorno 10/gen/2014 20:09, "Markus Neteler" <neteler at osgeo.org> ha
>> > scritto:
>> >> On Fri, Jan 10, 2014 at 7:47 PM, Carmine Massarelli
>> >> > Hello,
>> >> > I want only to advice you that the last version of Grass 6.4.2.
>> >> > (downloaded
>> >> > with Qgis for 64-bit system) does not function. The module d.rast
>> >> > goes
>> >> > in
>> >> > crash and it is not possible to visualize the map. The error is not
>> >> > in
>> >> > the
>> >> > same version for 32-bit system.
>> >> Please let us know which operating system are you using here.
>> >> Ideally, also send the error message.
>> >> BTW: The latest version is GRASS GIS 6.4.3.
>> >> Best regards
>> >> Markus Neteler
>> >> http://courses.neteler.org/blog/
More information about the grass-web mailing list
