[GRASS-web] New Brunswick Double Stereographic Projection
Russell Crosby
russcrosby at hotmail.com
Fri Oct 3 11:01:55 PDT 2014
To Whom It May Concern:
Regarding GRASS GIS, there is a projection called New Brunswick Double Stereographic projection that is not apparently included in the list of projections. How do I get these parameters into GRASS so I can work in this projection?
The parameters for it is:
PROJCS["NAD_1983_CSRS_New_Brunswick_Stereographic",GEOGCS["GCS_North_American_1983_CSRS",DATUM["D_North_American_1983_CSRS",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Double_Stereographic"],PARAMETER["False_Easting",2500000.0],PARAMETER["False_Northing",7500000.0],PARAMETER["Central_Meridian",-66.5],PARAMETER["Scale_Factor",0.999912],PARAMETER["Latitude_Of_Origin",46.5],UNIT["Meter",1.0]]
Thank you for making available such a usefull GIS.
Regards
Russ
Russell Crosby, M.Sc., P.Geo.Registered Professional GeologistCrosby Consulting & Exploration Services
NEW PHONE NUMBERSTel: (506) 455-0881Fax: (506) 455-5888Cell: (506) 471-5950
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20141003/25fdc5ce/attachment.html>
More information about the grass-web
