[GRASS-web] The New version
Markus Neteler
neteler at osgeo.org
Fri Nov 10 05:10:38 PST 2017
Hi Helmut,
do you have a hint for us? Maybe it is already explained... Thanks!
Mobile greetings,
Markus
On Nov 10, 2017 11:10 AM, "IBRAHIM IBRAHIM" <ibra.alwafa at gmail.com> wrote:
> Thank you very much that was super help full !!! ....... one final
> question in the 6.4 version i used to write my code in Notepad and save it
> as ".bat" then i use the "sh" command to run it but i seems not to work on
> 7.2 version
> thanks in advance
> On Fri, Nov 10, 2017 at 1:06 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Dear
>> On Thu, Nov 9, 2017 at 3:47 PM, IBRAHIM IBRAHIM <ibra.alwafa at gmail.com>
>> wrote:
>> > Dear GRASS Development Team
>> > I used to use Grass 6.4.2 and some times its very slow and doesn't show
>> the
>> > full map when i do d.rast so i decided to use Grass 7.2.0 but
>> unfortunately
>> > i couldn't find the command r.los is it there with a different name of
>> its
>> > removed ?
>> yes, it got a different, more understandable name: r.viewshed. And it
>> got WAY faster!
>> For a lookup table, see
>> https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
>> Regards,
>> Markus Neteler, PhD
>> http://www.mundialis.de - free data with free software
>> http://grass.osgeo.org
>> http://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20171110/1b7012b5/attachment.html>
More information about the grass-web
