[GRASS-web] Addons on MS
Helmut Kudrnovsky
hellik at web.de
Fri Aug 10 12:51:47 PDT 2018
Markus Neteler wrote
> (please keep it on the list)
> Lucila Dunnington <
> lucila.dunnington@
> > schrieb am Fr., 10. Aug.
> 2018, 19:43:
>> Downloading precompiled GRASS Addons
> <r.stream.distance>
>> Downloading source code for
> <r.stream.distance>
> from <
>> http://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.1/r.stream.distance.zip>
>> which is identified as 'remote_zip' type of source...
>> ERROR: Extension
> <r.stream.distance>
> not found
>> r.stream.distance
> Maybe a WINDOWS user here could help, I'm on Linux.
unfortunately the winGRASS build environment seems to have some hickups/to
be down at the moment.
according to the error log, it seems you're usung winGRASS 7.4.1.
have a look into
https://wingrass.fsv.cvut.cz/grass74/x86_64/addons/grass-7.4.1/
download there manually
r.stream.distance.zip 2018-08-05 23:26 93K
and unzip the files into the addon folder, e.g
C:\Users\YourUserName\AppData\Roaming\GRASS7\addons
the exe into the bin subfolder, the html file into the appropriate
subfolder.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Website-f4053612.html
More information about the grass-web
