[GRASS-web] Installing r.green is not possible
Zambelli Pietro
Pietro.Zambelli at eurac.edu
Wed Nov 20 22:05:49 PST 2019
Dear Annamarie,
sorry for the delay, finally yesterday I did have time to test the installation process on my machine and I got a similar error highlight by Markus regarding the libgreen/libhydro it seems that the makefile as it is is not any more able to handle some internal library.
To get the module installed and working you could
Download the source code with:
$ g.extension extension=r.green -d
you will get a message similar to the follow:
Fetching <r.green> from GRASS GIS Addons repository (be patient)...
To compile run:
make MODULE_TOPDIR=/usr/lib64/grass78 \
RUN_GISRC=/tmp/grass7-pietro-65803/gisrc \
BIN=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/bin\
HTMLDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/docs/html \
RESTDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/docs/rest \
MANBASEDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/docs/man \
SCRIPTDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/scripts \
STRINGDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green \
ETC=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/etc\
SOURCE_URL=https://trac.osgeo.org/grass/browser/grass-addons/grass7/
To install run:
ARCH_DISTDIR=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green \
INST_DIR=/home/pietro/.grass7/addons install
Path to the source code:
Before executing the command suggested by g.extension module you have to set the PYTHONPATH variable as follow:
export PYTHONPATH=<your r.green path>:<your r.green path>/r.green.hydro:$PYTHONPATH
So in my case is:
export PYTHONPATH=/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green:/tmp/grass7-pietro-65803/tmpixl0y9dg/r.green/r.green.hydro:$PYTHONPATH
Please let me know if the above command fix your issue, if not please provide more details regarding your OS/configuration and your errors.
Best regards
Pietro
Pietro Zambelli
Eurac Research
Institute for Renewable Energy
Tel +39 0471 055 684
Fax +39 0471 055 699
pietro.zambelli at eurac.edu<mailto:laura.scafidi at eurac.edu>
Via A.Volta 13/A
39100 Bozen/Bolzano
Legal Seat
Drususallee/Viale Druso 1
I-39100 Bozen/Bolzano
www.eurac.edu<http://www.eurac.edu>
Facebook<https://facebook.com/eurac.research> l Youtube<https://www.youtube.com/EURACtv> l Twitter<https://twitter.com/eurac> l LinkedIn<https://www.linkedin.com/company/euracresearch>
According to regulation (EU) 2016/679 this transmission is intended only for the use of the addressee and may contain confidential information. If you receive this transmission in error, please notify the sender immediately by email and delete all copies of this message and any attachments.
Sent: 11 November 2019 18:46
To: Annemarie Pfeiffer <Annemarie.Pfeiffer at umwelt.uni-giessen.de>
Cc: GRASS-web <grass-web at lists.osgeo.org>; andre grosse-stoltenberg <Andre.Grosse-Stoltenberg at umwelt.uni-giessen.de>
Subject: Re: [GRASS-web] Installing r.green is not possible
Dear Annemarie,
Which GRASS GIS version do you use, and on which operating system?
I have tried to install it myself, on a Linux system:
GRASS 7.8.2dev (nc_spm_08):~ > g.extension r.green
Compiling...
File "/home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/scripts/r.green.hydro.structure",
line 139, in <module>
from libgreen.checkparameter import check_required_columns, exception2error
ModuleNotFoundError: No module named 'libgreen'
make[2]: *** [/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-gnu/include/Make/Html.make:14:
r.green.hydro.structure.tmp.html] Error 1
/home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/scripts/r.green.install:35:
DeprecationWarning: the imp module is deprecated in favour of
importlib; see the module's documentation for alternative uses
import imp
Installing...
/usr/bin/install: cannot stat
'/home/mneteler/tmp/grass7-mneteler-20201/tmpfggv6w9y/r.green/docs/html/r.green.hydro.structure.html':
No such file or directory
make[2]: *** [/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-gnu/include/Make/Script.make:36:
install] Error 1
Updating addons metadata file...
Updating private addons metadata file...
WARNING: No addons metadata available. Addons metadata file not updated.
Installation of <r.green> successfully finished
GRASS 7.8.2dev (nc_spm_08):~ > r.green.
r.green.biomassfor.co2 r.green.biomassfor.recommended
r.green.gshp.theoretical r.green.hydro.financial
r.green.hydro.technical
r.green.biomassfor.financial r.green.biomassfor.technical
r.green.hydro.closest r.green.hydro.optimal
r.green.hydro.theoretical
r.green.biomassfor.impact r.green.biomassfor.theoretical
r.green.hydro.delplants r.green.hydro.planning
r.green.install
r.green.biomassfor.legal r.green.gshp.technical
r.green.hydro.discharge r.green.hydro.structure
Some issue seems to be there with "libgreen".
Do you see the same error?
Best regards,
Markus
On Wed, Nov 6, 2019 at 11:38 AM Annemarie Pfeiffer
<Annemarie.Pfeiffer at umwelt.uni-giessen.de> wrote:
> Dear Sir or Madam,
> as part of my master's thesis I would like to use the tool
> r.green.hydro with all its functions. After I've completed all the
> steps of your detailed online installation guide, Grass-Gis will
> create a field called "Energy." The functions of this field are grayed
> out and can not be executed. After entering the r.green.install -x
> command, you also receive the message that the python libraries
> numexpr and scipy are not available. After I installed these manually,
> the message did not occur anymore, but the functions in "Energy" were
> also not executable and still written in gray.
> Additionally, when you load Grass-GIS into the black console, you see
> the following message:
> Details: Can not find the executable r.green.hydro ....
> r.green.hydro ...: Unable to fetch interface description for command
> 'r.green.hydro ....' "
> Since I would benefit greatly from the use of the tool for my
> explorations, I would be very grateful if you could help me with my
> problem.
> With best regards
> Annemarie Pfeiffer
> Mit freundlichen Grüßen
> Annemarie Pfeiffer
> grass-web mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-web
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20191121/6a0e32d8/attachment-0001.html>
More information about the grass-web
