[GRASS-web] GrassGIS系统启动错误。
xuzhh at drgis.com xuzhh at drgis.com
Fri Sep 27 15:54:52 PDT 2019
您好:
全新安装的Windows10系统,下载grass7.6.1,安装中提示下载WindowsC++ redistribution package失败。但安装完成了。
另外,单独下载安装了WindowsC++ redistribution package 2015。
启动时出现下列信息。
反复尝试过几次,提示信息都是这样的。
请问如何解决?
Cleaning up temporary files...
Starting GRASS GIS...
  File "C:\Program Files\GRASS GIS 7.6\gui\wxpython\gis_set.py", line 42, in <module>
    from startup.guiutils import SetSessionMapset, NewMapsetDialog
  File "C:\Program Files\GRASS GIS 7.6\gui\wxpython\startup\guiutils.py", line 25, in <module>
    from gui_core.dialogs import TextEntryDialog
  File "C:\Program Files\GRASS GIS 7.6\gui\wxpython\gui_core\dialogs.py", line 44, in <module>
    from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
  File "C:\Program Files\GRASS GIS 7.6\gui\wxpython\gui_core\gselect.py", line 70, in <module>
    from grass.pygrass import messages
  File "C:\Program Files\GRASS GIS 7.6\etc\python\grass\pygrass\messages\__init__.py", line 19, in <module>
    import grass.lib.gis as libgis
  File "C:\Program Files\GRASS GIS 7.6\etc\python\grass\lib\gis.py", line 23, in <module>
    _libs["grass_gis.7.6"] = load_library("grass_gis.7.6")
  File "C:\Program Files\GRASS GIS 7.6\etc\python\grass\lib\ctypes_loader.py", line 62, in load_library
    return self.load(path)
  File "C:\Program Files\GRASS GIS 7.6\etc\python\grass\lib\ctypes_loader.py", line 240, in load
    return _WindowsLibrary(path)
  File "C:\Program Files\GRASS GIS 7.6\etc\python\grass\lib\ctypes_loader.py", line 223, in __init__
    self.cdll = ctypes.cdll.LoadLibrary(path)
  File "C:\Program Files\GRASS GIS 7.6\Python27\lib\ctypes\__init__.py", line 444, in LoadLibrary
    return self._dlltype(name)
  File "C:\Program Files\GRASS GIS 7.6\Python27\lib\ctypes\__init__.py", line 366, in __init__
    self._handle = _dlopen(self._name, mode)
WindowsError: [Error 126]
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
     grass76 --help
See also: https://grass.osgeo.org/grass76/manuals/helptext.html
Exiting...
请按任意键继续. . .
xuzhh at drgis.com
URL: <http://lists.osgeo.org/pipermail/grass-web/attachments/20190928/9d7ace79/attachment.html>
More information about the grass-web mailing list
