[winGRASS] Installation Problems
Kirk Schmidt
kirkschmidt at auracom.com
Wed Apr 24 09:39:01 EDT 2002
Good Morning:
I have been diligently working through the installation of grass5 for
cygwin on a windows system (actually windows 98) I ran into a couple of
minor snags with the install shell but that seems to have been overcome
(a problem with the filesize checker). I have installed cygwin and it is
operating as well. I also installed the evaluation version of Star Net
Xwin-32 and it appears to work OK.
When I activate cygwin and type in "grass5 help" I get the help
standard help files which originate from the file file
cygwin/usr/local/bin/grass5.sh
This indicates that all is well.
When I enter "grass5 -tcltk" i get the following message:
usage: /usr/local/grass5/etc/lock file pid
unable to properly access /home/Kirk Schmidt/.gislock5
Upon checking the path to /home/Kirk Schmidt/ I only find a BASH
history file
Does anybody have any idea what the problem is?
I assume I have to generate a file called "gislock5" but what does it
contain?
Still trying
Kirk Schmidt
More information about the grass-windows
