[winGRASS] Re: Vectorization
    Markus Neteler
    neteler at itc.it
    Wed Feb 20 03:33:31 EST 2002
On Wed, Feb 20, 2002 at 10:52:13AM -0800, Bipin Charles wrote:
> Dear Wingrass users,
> I have following problem, after digitizing raster map how do I save as vector file ?
> thanks
Hi bipin,
when starting v.digit, it will ask you for a vector file name.
The vectors are automatically stored in this file (=map).
You can just leave v.digit, then run v.support on the map
to build the topology and display it with d.vect.
Hope this helps,
 Markus
More information about the grass-windows
