[winGRASS] Re: Importing from erdas lan
Markus Neteler
neteler at itc.it
Wed Feb 27 10:27:00 EST 2002
On Wed, Feb 27, 2002 at 04:33:13PM +0530, Bipin Charles wrote:
> Dear grass users,
> Iam currently using grass 5.x pre2. Recently I tried importing MSS data
> which is in erdas lan format to grass, the problem is, I could'nt read
> projection information after import or in other words the projection
> info was overwritten. Further, How do I import along with projection
> info from erdas lan to grass and similarly how do I export along with
> projection information to erdas.
which module did you use: r.in.gdal or i.in.erdas?
For the second question: There is i.out.erdas to export in
erdas lan format from GRASS.
Markus
More information about the grass-windows
