[winGRASS] some really slooooowwww functions
Matt & Kim
patawi at polarcom.com
Tue Jan 29 07:36:48 EST 2002
Hi All,
This is my first post to wingrass, though I've been a lurker on
the main grass channel for a year so and have opened my mouth
there once or twice. I'm a GIS professional (ArcInfo, plus a
smattering of others) and am trying to get seriously acquainted
with grass. My coding ability in anything other than Arc Macro
Language or dos/nt cmd files is pretty close to nil, sorry.
Cheers.
I'm sure I'll have more questions later, but at the moment there
are only 2. I have no idea if they are related.
1) When running many grass commands instead of the expected
output I get:
grass5.0.0pre2_i686-pc-cygwin_bin.tar.gz: No such file or directory
for example:
GRASS:/usr/local > g.setproj
WARNING! A projection file '/home/obelix1/g-data/yk/PERMANENT/PROJ_INFO'
[...snip...]
Please specify projection name
Enter 'list' for the list of available projections
Hit RETURN to cancel request
>list
For the above session a text file containing the expected
output can be found in
D:\cygwin\home\Obelix1\g-data\yk\landsat7\.tmp\OBELIX\1396.0
In an attempt to remedy the situation I uninstalled grass5pre2
(using the uninstall script) and installed grass5pre3 by simply
unpacking the archive into /usr/local/grass5 and symlinking
the grass5 startup script to /usr/local/bin/grass5.
The error message remains the same. Note the 'pre2' in the
filename. The pre2 archive no longer exists anywhere on my
harddrive.
2) I've been trying to bring in some GeoTiff imagery and it is
taking an incredibly long time, over 12 hours for a single 17.6mb
image using r.in.tiff. This can't be normal (right? please?)
Task manager reported ~150mb of ram being used and 99%
CPU utilization (figures from memory and before I upgraded
to pre3).
Right now I am using r.in.tiff on a 4.4mb geotiff. At about
the 12 minute mark Task Manager reports:
r.in.tiff
cpu% : 99 (range is 85-99)
cpu time : 09:00
memory : 69,040 K (going up, very slowly)
processes : 42
memory usage : 374,094 K / 1,277,936 K
The cdrom drive where the source image lies spins up every 5
minutes or so. (In previous tests the same slowness is observed
on images on the harddrive and within the cygwin directory
tree).
Host system:
Windows 2000, service pack2
512mb ram
40gb IDE harddrive (8gb FAT, 10GB NTFS, rest unassigned)
abit kt7a-raid motherboard
athlon 1100mhz cpu
$uname -a
CYGWIN_NT-5.0 OBELIX 1.3.6(0.47/3/2) 2001-12-08 17:02 i686 unknown
$ df
Filesystem 1k-blocks Used Available Use% Mounted on
D:\cygwin\bin 10241404 7761544 2479860 76% /usr/bin
D:\cygwin\lib 10241404 7761544 2479860 76% /usr/lib
D:\cygwin 10241404 7761544 2479860 76% /
c: 10223368 9758616 464752 96% /cygdrive/c
d: 10241404 7761544 2479860 76% /cygdrive/d
e: 498224 498224 0 100% /cygdrive/e
thanks in advance for any assistance you can provide,
-matt wilkie
whitehorse, yukon, canada
More information about the grass-windows
