[winGRASS] Can't start  TCLTKGRASS in winGrass with generic version
    Hisaji ONO
    hi-ono at mn.xdsl.ne.jp
    Tue Mar 26 11:41:10 EST 2002
 Thank you for your response, Mr. Neteler.
> If you are refering to winGRASS without Xserver requirement, the
> "tcltkgrass" is not present because there are limitations in the
underlying
> tcl/tk libraries. You may try to install "ActiveTcl" to overcome the
> problem:
>  http://aspn.activestate.com/ASPN/Downloads/ActiveTcl/
> eventually then it will be working. Please inform us about your results
> when trying ActiveTcl.
 I've already installed this, but the result was same.
Best regards
More information about the grass-windows
