[winGRASS] Re: [GRASS5] Windows native Xdriver
Mike Thomas
mthomas at gil.com.au
Thu May 2 16:39:02 EDT 2002
Hi Glynn
> > As /dev doesn't exist on my computer, this wonn't work for me (and I
suspect
> > many Cygwin users).
> Cygwin implements device files such as /dev/tty, /dev/null and
> /dev/windows internally. Try "ls -l /dev/windows"; it works, even
> though there isn't a /dev/directory.
Spot on, thanks. I appreciate your patient technical explanations - my
personal programming preferences lie far away from the world of sockets and
Unix emulation on Windows!
Getting back to your earlier request for feedback on Windows NT, using:
fd = open ("/dev/windows", O_NONBLOCK, 0);
on my Windows XP computer is an improvement as it allows 3 Xdriver window
refreshes (generated by covering and then uncovering the window with the
Grass console window) before the XDriver degenerates into the buffered event
behaviour described earlier.
This is probably being caused by the repeated opening using up some internal
fd buffer - caching the fd by making it static cures the problem:
int
XConnectionNumber(Display* display)
static int fd = 0;
NT_debug ("XConnectionNumber\n");
if ( 0 == fd ) {
if ( -1 == fd ) {
NT_log ("XConnectionNumber unable to open /dev/windows, errno = %d\n",
errno);
return ( fd );
This, of course assumes that nobody will close the fd. Is that likely?
I'll check in the changes when a little more testing has been done and when
I have an answer to the above question.
Cheers
MIke Thomas.
More information about the grass-windows
