[winGRASS] problems starting grass5
    Glynn Clements
    glynn.clements at virgin.net
    Sun May 19 08:46:10 EDT 2002
Vincent Roy wrote:
> I have installed winGrass on my box and so far the
> intallation seems to have worked out. However, I am
> unable to get grass to start. The grass5 command
> results in the following msg.
>  $grass5
> [: Roy/.grassrc5 unkown operand
> usage: /usr/local/grass5/etc/lock file pid
> Unable to properly access /home/Vincent Roy/.gslock5
> please notify system personel
> Does anyone have any suggestions
Much of GRASS currently fails to handle spaces in filenames. You will
have to arrange for $HOME to be set to a path which doesn't contain
any spaces.
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
