[GRASS5] RE: [winGRASS] GRASS 5.0.0 released!
Malcolm Blue mblue at nb.sympatico.ca
Mon Sep 9 11:56:13 EDT 2002
Glynn,
> Hmm. GNU libc's math.h also declares "round", but only if
> __USE_ISOC9X is defined. I wonder if Cygwin's gcc defaults to
> C9X rather than C89.
It appears to. Round is declared after:
#ifndef __STRICT_ANSI__
/* ISO C99 types and macros. */
> IIRC, the most recent versions of gcc (3.x, maybe some later
> 2.9x) have an option to select the dialect (C89/C9X), so it
> may be possible to get around this problem by setting CFLAGS
> prior to running "configure".
You are right, I could have defined __STRICT_ANSI__ to avoid this error.
Thanks,
Malcolm
> In any case:
> 1. We should probably pick another name for the function in
> d.zoom/cmd/set.c. "round(x)" is normally understood as
> meaning the same thing as "floor(x+0.5)".
> 2. We should consider whether configure should attempt to
> detect the existence of a round() function, and define
> HAVE_ROUND accordingly; imagery/i.pca/cmd/main.c could then
> conditionalise its local definition.
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
More information about the grass-windows mailing list
