[winGRASS] problems with tcltkgrass
grass at karsten-lessing.de
Fri Aug 8 04:26:02 EDT 2003
Hello,
My PC is running under Win2000 and I have some problems with tcltkgrass:
Definitively I installed the whole package of cygwin which I´ve got
http://xfree86.cygwin.com/
so also xFree86 und X11R6.4 should be came with it !
I am also sure that I installed the right package of GRASS with xserver
support and the spearfish dataset!
To start GRASS with tcltk I do the following:
start Cygwin as described under:
http://grass.baylor.edu/grass5/binary/windows_cygnus/cygwin_grass50bininstall.html
In the appearing terminal I type in:
"startxwin.bat"
After starting grass5 and the spearfishdataset
GRASS:~ >
appears regular.
But after calling up:
"tcltkgrass&"
the following error promt appears:
/usr/X11R16/bin/xwininfo: unable to open display"
usage: /usr/X11R16/bin/xwininfo [-options ...]
where options include:
-help print this message
-display host dpy ....
while executing
"exec xwininfo [winfo id .w_g] | grep -i Corners"
invoked from within
"scan [exec xwininfo -id [wininfo id .w_g] < grep -i Corners] {%*s %d%d}
dx dy"
(file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1887)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
(file "/usr/local/grass5/bin/tcltkgrass" line 21)
can anybody help ???
best regards
Karsten
More information about the grass-windows
