[winGRASS] RE: winGRASS digest, Vol 1 #183 - 1 msg
    Gerry James
    gjames at bgcengineering.ca
    Fri Aug  8 11:53:22 EDT 2003
Karsten,
When you have the Cygwin shell open try starting Grass (type grass5) then,
when you have the GRASS:~> prompt type startx .  this will open the xWindows
interface.  You can then type tcltkgrass at the GRASS promt in the xWindows
interface which should open the GRASS GUI.  Hopefully this works for you.
Gerry James
BGC Engineering Inc.
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of wingrass-request at grass.itc.it
Sent: Friday, August 08, 2003 3:01 AM
To: wingrass at grass.itc.it
Subject: winGRASS digest, Vol 1 #183 - 1 msg
Send winGRASS mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://grass.itc.it/mailman/listinfo/wingrass
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of winGRASS digest..."
Today's Topics:
   1. problems with tcltkgrass (grass at karsten-lessing.de)
--__--__--
Message: 1
To: <wingrass at grass.itc.it>
Date: Fri,  8 Aug 2003 10:26:02 +0200
Subject: [winGRASS] problems with tcltkgrass
Hello,
My PC is running under Win2000 and I have some problems with tcltkgrass:
Definitively I installed the whole package of cygwin which I´ve got
http://xfree86.cygwin.com/
so also xFree86 und X11R6.4 should be came with it !
I am also sure that I installed the right package of GRASS with xserver
support and the spearfish dataset!
To start GRASS with tcltk I do the following:
start Cygwin as described under:
http://grass.baylor.edu/grass5/binary/windows_cygnus/cygwin_grass50bininstal
l.html
In the appearing terminal I type in:
"startxwin.bat"
After starting grass5 and the spearfishdataset
GRASS:~ >
appears regular.
But after calling up:
"tcltkgrass&"
the following error promt appears:
/usr/X11R16/bin/xwininfo: unable to open display"
usage: /usr/X11R16/bin/xwininfo [-options ...]
where options include:
-help    print this message
-display host dpy ....
while executing
"exec xwininfo [winfo id .w_g] | grep -i Corners"
   invoked from within
"scan [exec xwininfo -id [wininfo id .w_g] < grep -i Corners] {%*s %d%d}
dx dy"
   (file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1887)
   invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
   (file "/usr/local/grass5/bin/tcltkgrass" line 21)
can anybody help ???
best regards
Karsten
--__--__--
winGRASS at grass.itc.it
End of winGRASS Digest
More information about the grass-windows
