[winGRASS] Starting Grass5
Mike Thomas
miketh at brisbane.paradigmgeo.com
Wed May 7 22:45:10 EDT 2003
Hi Marc.
Grass can't deal with spaces in directory names unfortunately and there's a
space in your user name and consequently your home directory path name:
"Unabel to properly access /home/Marc Zapata/.gislock5"
Try running as a different user without spaces.
As an experiment it may also be possible to copy the directory "/home/Marc
Zapata" to something like "/home/marc" and edit your "/etc/passwd" file to
reflect that change (after making a backup copy of the file of course).
Also make sure that the value of the HOME environment variable reflects that
change. Be aware that this change could potentially mess up the system in
ways I can't predict.
Cheers
Mike Thomas
-----Original Message-----
From: wingrass-admin at grass.itc.it [mailto:wingrass-admin at grass.itc.it]On
Behalf Of Marc Zapata
Sent: Thursday, May 08, 2003 11:33 AM
To: wingrass at grass.itc.it
Subject: [winGRASS] Starting Grass5
Hi
I have just finished downloading and installing Cygwin and Grass 5.0 on
windows xp.
When I try to start Grass5 from the cygwin shell I get the following message
{: Zapata/. grassrc5: unknown operand
usage: /user/local grass5/etc/loc file pid
Please notify system personel.
Can anyone help me with this problem.
Cheers,
Marc.
Marc Zapata
Environmental Engineer
Asia Pacific Applied Science Assoc.
PO Box 1679, Surfers Paradise, Queensland 4217
tel: (07) 55-741-112
fax: (07) 55-741-112
mob: 0412 840 931
e-mail: mzapata at apasa.com.au
web: www.apasa.com.au
NOTICE: This e-mail, together with any attachments, is confidential and may
be the subject of legal privilege. If you are not the intended recipient,
please
e-mail us by return and delete this message. You are not permitted to
print, copy, disclose or use the content in any way. Thank you.
More information about the grass-windows
