[winGRASS] d.mon socket problem
Glynn Clements
glynn.clements at virgin.net
Tue May 20 12:54:47 EDT 2003
Markus Neteler wrote:
> A winGRASS problem still present is:
> GRASS >d.mon x0
> Socket is already in use or not accepting connections.
> Use d.mon to select a monitor
> Problem selecting x0. Will try once more
> -> the monitor window opens, but is not yet accessible.
> The socket file in /tmp/grass-$USER/ is generated
> The background is grey
> GRASS: > d.mon select=x0
> -> now the monitor works (d.rast etc)
> The socket file is not touched a second time.
> The background is black as expected.
1. Is this with the "generic" version or the X11 version?
2. Are you saying that display commands don't work until you have
performed an explicit "d.mon select..."?
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
