[winGRASS] Re: Installation problems
van der Mark, C.J. <xs4all account via olvg> cvdmark at xs4all.nl
Tue Aug 10 09:53:18 EDT 2004
Thanks again Richard,
Some of these commands were in the install-how2's of 5.0.3
I got an error on the $ /usr/X11R6/bin/XWin.exe  -multiwindow  -clipboard & command, but I remember executing the command from the
home dir in Cygwin.
I'll try it later this evening after I reinstalled everything, making sure everything is there.
I will let you know the results :-)
Best regards,
Cees
----- Original Message -----
From: "Richard Greenwood" <rich at greenwoodmap.com>
To: "van der Mark, C.J. <xs4all account via olvg>" <cvdmark at xs4all.nl>
Cc: <wingrass at grass.itc.it>
Sent: Tuesday, August 10, 2004 2:57 PM
Subject: Re: [winGRASS] Re: Installation problems
> van der Mark, C.J. <xs4all account via olvg> wrote:
> >>>How are you starting GRASS? I would suggest starting the Cygwin Bash
> >>>shell, and then type "grass5". This should get you started in text mode.
> >>>If that works, quit Grass and start X-Windows, then start Grass.
> >>>Regards,
> >>>Richard Greenwood
> >>>www.greenwoodmap.com
> >>I will try the order of doing things you suggested later tonight,
> >>Thanks!
> > OK Richard, tried it, no succes.
> > I then deinstalled Grass and reinstalled it using the installation instructions for 5.0.3
> > worked my way down, also installed the spearfish tut/example files
> > Started GRASS in the bash-shell, filled out the name,location and so on, then grass started.
> > Typed exit, leaving GRASS..no problem
> > Then I fired up the Xwin batch file and started grass again
> > got a little win-box with the files to choose from, took one, pressed OK and errors again, tried another (looking at the
Spearfish tut manuals)...errors again.
> What exactly are the error messages?
> > I think I will deinstall everyting, from GRASS to Cygwin, destroy all the directories until no trace is left of it all. Then
reboot and reinstall the whole thing.
> > Any other suggestions?
> Try this from the Bash shell:
> Nothing obvious will change, but you should see the Cygwin/X Server in
> your system tray. Then:
>     $ grass5
> Hopefully you will be in text mode, and select a Grass dataset. Then:
>     $ d.mon x1
> This should get a graphics monitor going.
> Regards,
> Richard Greenwood
More information about the grass-windows mailing list
