[winGRASS] Compile GRASS 5.3 in cygwin: can't find includes
Glynn Clements
glynn.clements at virgin.net
Mon Aug 30 04:56:18 EDT 2004
Stefaan Lhermitte wrote:
> Im trying to complie GRASS 5.3 in the Cygwin environment but with the
> specific ODBC, FFTW and proj features included. I've checked all
> requierements and installed the FFTW and Proj features;
> When I run:
> ./configure --without-postgres --with-odbc-libs=/usr/local/lib
> --with-fftw-includes=/usr/local/fftw_3.0.1/include
You need FFTW 2.x; 3.x isn't compatible.
> --with-fftw-libs=/usr/local/fftw_3.0.1/lib
> --with-proj-include=/usr/local/proj_4.4.8/include
> --with-proj-libs=/usr/local/proj_4.4.8/lib
> I get the following error message:
> Unable to locat FFTW includes
> I don't know what id do wrong since i specify the FFTW include and the
> file fftw.h is in that folder.
> I the config.log, The following can be found:
> configure:9516: checking whether to use FFTW
> configure:9535: checking for location of FFTW includes
> configure:9561: checking for fftw.h
> configure:9569: gcc -E -I/usr/local/fftw_3.0.1/include conftest.c
> >/dev/null 2>conftest.out
> configure:9565:18: fftw.h: No such file or directory
That seems pretty conclusive, i.e. the compiler (specifically, the
preprocessor) fails to find fftw.h.
Could this be a Cygwin issue? Does:
cat /usr/local/fftw_3.0.1/include/fftw.h
(from a bash shell) work?
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
