[winGRASS] Re:winGRASS digest, Vol 1 #250 - 3 msgs
josanabria
josanabria at terra.com.co
Fri Dec 3 10:12:41 EST 2004
Por favor necesito alguien que hable español tengo inconvenientes con la parte de interfaz grafica instalando GRASS en Windows con cygwin> Send winGRASS mailing list submissions to
> wingrass at grass.itc.it
> To subscribe or unsubscribe via the World Wide Web, visit
> http://grass.itc.it/mailman/listinfo/wingrass
> or, via email, send a message with subject or body 'help' to
> wingrass-request at grass.itc.it
> You can reach the person managing the list at
> wingrass-admin at grass.itc.it
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of winGRASS digest..."
> Today's Topics:
> 1. Re: Grass 5.4? (Glynn Clements)
> 2. wingrass (nhrao at deas.harvard.edu)
> 3. Re: Welcome to the "winGRASS" mailing list (Digest mode) (Natalie O'Toole)
> --__--__--
> Message: 1
> From: Glynn Clements
> Date: Thu, 2 Dec 2004 10:26:30 +0000
> To: luke at rwa.co.za
> Cc: wingrass at grass.itc.it
> Subject: Re: [winGRASS] Grass 5.4?
> luke at rwa.co.za wrote:
> > I see that Grass 5.4 is now avalible to linux users. How about cygwin?
> > is it going to be ported here eventually? I see that the download default
> > is 5.3 even though it says 5.4. 5.3 is now longer supported.
> It shouldn't need to be "ported"; all versions of the GRASS source
> code ought to compile under Cygwin (if it doesn't, and the developers
> are made aware of that, it will be fixed).
> As for binaries, they'll be available when someone builds them and
> makes them available for distribution. I'm sure that the maintainers
> of the grass.itc.it site will be willing to host them, but I don't
> think that any of the developers at ITC actually use Cygwin, so it's
> dependent upon someone who does have Cygwin building them.
> Glynn Clements
> --__--__--
> Message: 2
> Date: Thu, 2 Dec 2004 11:24:14 -0500 (EST)
> From: nhrao at deas.harvard.edu
> To: wingrass at grass.itc.it
> Subject: [winGRASS] wingrass
> I have downloaded and installed the Wingrass (5.7.0) primaries. I am
> totally new to GRASS and Unix. I have experience other gis like ArcGIS. I
> have also downloaded the spearfish dataset.
> after typing startx and grass57 in the cygwin window, the interface asking
> for the database location etc. opens. how do i move from here. can someone
> take me through the initial steps. the online manual does not seem to have
> the details or can someone point me to a starter manual.
> thanks
> nhrao
> --__--__--
> Message: 3
> From: "Natalie O'Toole"
> Date: Thu, 2 Dec 2004 10:19:02 -0700
> Subject: [winGRASS] Re: Welcome to the "winGRASS" mailing list (Digest mode)
> This is a multipart message in MIME format.
> --=_alternative 005F32F587256F5E_=
> Content-Type: text/plain; charset="US-ASCII"
> Hi,
> My name is Natalie and I work for the Mount Royal College Library in
> Calgary, Alberta, and I'm a first-time user of GRASS. My question is:
> I'm trying to install GRASS on the MS Windows platform: what is the Cygwin
> tool used for? Whenever I run the Cygwin tool the interace only shows up
> for one second. Also, when installing GRASS, when I have to type in: sh
> grass5install.sh grass5package_bin.tar.gz, do I have to do this in UNIX,
> or can I use a DOS prompt, or do I use Cygwin?
> Please let me know!
> Thanks,
> Natalie O'Toole
> Data Information Specialist
> This communication is intended for the use of the recipient to which it is
> addressed, and may
> contain confidential, personal, and or privileged information. Please
> contact the sender
> immediately if you are not the intended recipient of this communication,
> and do not copy,
> distribute, or take action relying on it. Any communication received in
> error, or subsequent
> reply, should be deleted or destroyed
> Content-Type: text/html; charset="US-ASCII"
> Mount Royal College Library in Calgary, Alberta, and I'm a first-time user
> Windows platform: what is the Cygwin tool used for? Whenever I run the
> Cygwin tool the interace only shows up for one second. Also, when
> installing GRASS, when I have to type in: sh grass5install.sh grass5package_bin.tar.gz,
> do I have to do this in UNIX, or can I use a DOS prompt, or do I use Cygwin?
Please let me know!
Thanks,
Natalie O'Toole
> is addressed, and may
> contain confidential, personal, and or privileged information. Please contact
> the sender
> and do not copy,
> --=_alternative 005F32F587256F5E_=--
> --__--__--
> winGRASS at grass.itc.it
> End of winGRASS Digest
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20041203/0eff1ed4/attachment.html
More information about the grass-windows
