[winGRASS] the " libgrass_gis.dll was not found !" problem
Koukoulas Sotiris
skouk at geo.aegean.gr
Sun Dec 12 16:14:29 EST 2004
Ok, did what you said and here are the new outputs (no I did not compile
it myself - I used the binary that you provided, but it seems that it
can not locate a couple of libraries: libgrass_gis.dll AND
libgrass_I.dll...)
******************* OUTPUT 1
$ cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
P:/cygwin/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
P:\cygwin\bin\cygwin1.dll
C:\WINDOWS\system32\ADVAPI32.DLL
C:\WINDOWS\system32\ntdll.dll
C:\WINDOWS\system32\KERNEL32.dll
C:\WINDOWS\system32\RPCRT4.dll
.\libgrass_I.5.7.cvs.dll
.\libgrass_vask.5.7.cvs.dll
P:\cygwin\bin\cygncurses-8.dll
.\libgrass_gis.5.7.cvs.dll
P:\cygwin\bin\cygz.dll
.\libgrass_datetime.5.7.cvs.dll
.\libgrass_gmath.5.7.cvs.dll
.\libgrass_symb.5.7.cvs.dll
.\libgrass_gproj.5.7.cvs.dll
P:\cygwin\bin\cygproj-0.dll
P:\cygwin\usr\local\bin\cyggdal-1.dll
P:\cygwin\bin\cygjasper-1-701-1.dll
P:\cygwin\bin\cygjpeg-62.dll
P:\cygwin\bin\cygpng12.dll
P:\cygwin\bin\pq.dll
P:\cygwin\bin\cygcrypt-0.dll
P:\cygwin\bin\cygcrypto-0.9.7.dll
P:\cygwin\bin\cygssl-0.9.7.dll
P:\cygwin\bin\cygtiff4.dll
Error: could not find libgrass_gis.dll
Error: could not find libgrass_I.dll
.\libgrass_vect.5.7.cvs.dll
.\libgrass_dbmibase.5.7.cvs.dll
.\libgrass_dbmiclient.5.7.cvs.dll
.\libgrass_linkm.5.7.cvs.dll
.\libgrass_rtree.5.7.cvs.dll
.\libgrass_dgl.5.7.cvs.dll
.\libgrass_dig2.5.7.cvs.dll
******************** OUTPUT 2
GRASS 5.7.cvs:~ > d.m &
[1] 3708
GRASS 5.7.cvs:~ > Error in startup script: child process exited
abnormally
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file
"/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/etc/dm/d.m.tcl" line
875)
[1]+ Exit 1 d.m
GRASS 5.7.cvs:~ > cygcheck
P:\cygwin\usr\local\grass5.7.cvs-i686-pc-cygwin-11_12_2004\lib\libgrass_
I.5.7.cvs.dll
vask.5.7.cvs.dll
gis.5.7.cvs.dll
gmath.5.7.cvs.dll
symb.5.7.cvs.dll
gproj.5.7.cvs.dll
vect.5.7.cvs.dll
linkm.5.7.cvs.dll
rtree.5.7.cvs.dll
dgl.5.7.cvs.dll
dig2.5.7.cvs.dll
GRASS 5.7.cvs:~ >
-----Original Message-----
Sent: Sunday, December 12, 2004 4:13 AM
To: Koukoulas Sotiris
Cc: grass5 at grass.itc.it; wingrass at grass.itc.it; Patton, Eric;
info at thomas-reinfelder.de
Subject: Re: [winGRASS] the " libgrass_gis.dll was not found !" problem
OK, ps.map seems to be able to find all libraries.
But libgrass_gis.dll and libgrass_I.dll shouldn't be there. You know,
linked libraries cannot be loaded at run-time because M$-Windows doesn't
support UNIX link. Instead, these linked libraries are used at
compile-time. I don't know why your binary (should be the same as mine)
is linked against libgrass_gis.dll and libgrass_I.dll. Did you compile
it yourself?
Try the following:
1. Delete non 5.7.cvs.dll files and relink them:
cd /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/lib
for i in `/usr/bin/ls | grep -v 5.7.cvs | sed 's/\.dll$//'`
do
rm -f $i.dll
ln -s $i.5.7.cvs.dll $i.dll
done
2. cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
Now, ps.map shouldn't be able to find libgrass_gis.dll. Right?
Huidae Cho
On Sun, Dec 12, 2004 at 03:40:26AM +0200, Koukoulas Sotiris wrote:
> >Please check your library dependency of whatever command you run:
> >cygcheck /usr/local/grass.../bin/ps.map
> >Then it should print libraries that it requires. Try this in and
> outside
> >grass.
> Done that and here are the results (all not found files exist! -see
> lib_list attached):
> 1. Outside grass on the cygwin prompt: -------------------------------
> $ cygcheck
> Error: could not find libgrass_I.5.7.cvs.dll
> Error: could not find libgrass_gis.5.7.cvs.dll
> Error: could not find libgrass_symb.5.7.cvs.dll
> Error: could not find libgrass_gproj.5.7.cvs.dll
> Error: could not find libgrass_vect.5.7.cvs.dll
> 2. From grass5.7 prompt: -----------------------------------
> GRASS 5.7.cvs:~ > cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin
> I.5.7.cvs.dll
> vask.5.7.cvs.dll
> gis.5.7.cvs.dll
> gmath.5.7.cvs.dll
> symb.5.7.cvs.dll
> gproj.5.7.cvs.dll
> gis.dll
> I.dll
> vect.5.7.cvs.dll
> linkm.5.7.cvs.dll
> rtree.5.7.cvs.dll
> dgl.5.7.cvs.dll
> dig2.5.7.cvs.dll
> GRASS 5.7.cvs:~ >
More information about the grass-windows
